american the beautiful 4k and yellowstone 4k
smartieyoung
Post by smartieyoung »
I was just curious I was getting program can read data faster then it can write it to disk,i was able to copy both discs successfully and convert into mkv files.i attached a log here if anyone is curious,i think it might be a case of a bottleneck of data of from my Blu-ray drive to my actual hard drive.is this something i can fix?
MakeMKV_log.txt
(71.76 KiB) Downloaded 599 times
Re: american the beautiful 4k and yellowstone 4k
an hdd should have no problem writing at most 35MB/s sequential ripping you can try defragging that might help or maybe windows just decided it would do some read or write intensive stuff while you were ripping or maybe you did doesn't really matter. you could also go ssd but no point really for storing movies lol
smartieyoung
i think i might try looking at the settings, maybe there's something i can do, i try to offload my copied movies to an external hdd so there more space for ripping to run smoothly. :)
