The Grand Budapest Hotel
Mr_Orange
Post by Mr_Orange »
MakeMKV is showing 4 titles for The Grand Budapest Hotel BD (Region B).
The mpls is 00800 for all 4 although the segment map differs. They are listed as different angles. Is this playlist obfuscation and, if so, which one is correct?
Here is the output in the log:
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/generic.svq
BD+ code processed, got 1 FUT(s) for 19 clip(s)
File 00800.mpls (angle 1) was added as title #0
File 00800.mpls (angle 2) was added as title #1
File 00800.mpls (angle 3) was added as title #2
File 00800.mpls (angle 4) was added as title #3
Title 00850.mpls is equal to title 00800.mpls and was skipped
Failed to add angle #2 for title #850
Failed to add angle #3 for title #850
Failed to add angle #4 for title #850
File 00480.mpls was added as title #4
Title #00437.mpls(1) has length of 472 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00011.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00061.m2ts has length of 1 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00007.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00008.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00009.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00010.m2ts has length of 11 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00081.m2ts has length of 37 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00082.m2ts has length of 27 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00086.m2ts has length of 260 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00087.m2ts has length of 22 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00091.m2ts has length of 509 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00092.m2ts has length of 25 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00096.m2ts has length of 225 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00097.m2ts has length of 23 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00101.m2ts has length of 64 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00102.m2ts has length of 25 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00106.m2ts has length of 234 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00107.m2ts has length of 32 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00111.m2ts has length of 273 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00112.m2ts has length of 32 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00116.m2ts has length of 84 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00117.m2ts has length of 32 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00121.m2ts has length of 251 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00122.m2ts has length of 26 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00126.m2ts has length of 573 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00127.m2ts has length of 60 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00131.m2ts has length of 495 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00132.m2ts has length of 22 seconds which is less than minimum title length of 600 seconds and was therefore skipped
File 00136.m2ts was added as title #5
Title #00137.m2ts has length of 25 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00141.m2ts has length of 30 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00142.m2ts has length of 28 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00146.m2ts has length of 45 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00147.m2ts has length of 29 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00151.m2ts has length of 408 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00152.m2ts has length of 23 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00156.m2ts has length of 374 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00161.m2ts has length of 89 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00162.m2ts has length of 22 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00166.m2ts has length of 225 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00167.m2ts has length of 20 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00171.m2ts has length of 363 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00172.m2ts has length of 23 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00185.m2ts has length of 226 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00186.m2ts has length of 277 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00187.m2ts has length of 176 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00188.m2ts has length of 269 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00189.m2ts has length of 298 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00190.m2ts has length of 204 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00191.m2ts has length of 257 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00192.m2ts has length of 172 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00193.m2ts has length of 243 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00194.m2ts has length of 203 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00196.m2ts has length of 12 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00197.m2ts has length of 146 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00198.m2ts has length of 69 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00199.m2ts has length of 149 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00200.m2ts has length of 69 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00201.m2ts has length of 138 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00202.m2ts has length of 62 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00203.m2ts has length of 126 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00204.m2ts has length of 145 seconds which is less than minimum title length of 600 seconds and was therefore skipped
