The Doors Remastered 4K Key
hedcase
Post by hedcase »
Submitted my dump file for this title. Hoping it MakeMKV gets updated soon!
stuckinkodiagain
Re: The Doors Remastered 4K Key
Post by stuckinkodiagain »
Submitted my dump as well. Thanks to Mike!
hedcase
Post by hedcase »
Looks like the key is available. Thanks!
mstephens7
Post by mstephens7 »
Greetings. I just got this disc and my drive keeps trying to load it and then spits it out. Could I have a bad 4k disc? My Make MKV is up to date. Thanks for any thoughts in advance.
mstephens7 wrote:
Mon Jul 29, 2019 10:03 pm
What drive do you have
What firmware do you have
Do other uhd disks work
What is the build date of your drive
mstephens7
Apologies for such bad form asking a question. I should have included that info:
ASUS BW-16D1X-U on a new iMac (https://www.asus.com/us/Optical-Drives- ... /overview/)
I cannot locate what firmware it has - ASUS site has no updates for Mac
Other UHD have ripped just fine. Just did Die Hard 4k
Cannot locate the date.
I hope this helps-
M.
mstephens7 wrote:
Mon Jul 29, 2019 11:28 pm
I hope this helps-
M.
the ASUS BW-16D1X-U does not support UHD disks so you either have the model confused or you confused the die hard disk
What Billy said - that Asus cannot read UHD disks. I tried... and ended up giving it to someone who has no need for UHD.
mstephens7
Sincere apologies! I was a bit confused. Thanks for your help.
