Can't see any subtitles with Xtreamer pro or WMP
borje
Post by borje »
I cant't see any subtitles when using Xtreamer pro. I'm makieng MKV fils from Blu-ray discs and would like to see the subtitles that I select. I'm selecting all subtitles and audiotracks before making the mkv fil.
I have also used WMP but can't se any subtitles. For WMP I think I have all avaiable codeecs.
Icanseestars
Re: Can't see any subtitles with Xtreamer pro or WMP
Post by Icanseestars »
WMP does not support the MKV container.
For the Xtreamer you must manually enable subtitles within the settings menu of the player, if they still dont show you might have to convert the Blu-ray subtitles into SRT format.
borje
Post by borje »
Tanks fore the answer!
I'm new to this with media players. How do I convert the Blu-ray subtitles into SRT format?
skittle
Post by skittle »
There is no fully automatic way. But this tool will aid you: http://exar.ch/suprip/
