Using the filter process log method this is the one my blu-ray player chooses to play. I will have to watch it through to be sure but this method has never steered me wrong with lions gate films.MAJWoody wrote: Tue Jul 23, 2019 10:40 pm I tested 377 and I don't think that is the right one.... played side by side with disc (Leawo BR player) and did not match up 100%
Hellboy (2019) - Which Playlist?
WAYFLIX
Re: Hellboy (2019) - Which Playlist?
WAYFLIX
MKV is rarely ever correct.GyroDragona wrote: Tue Jul 23, 2019 9:11 pmThat is what makeMKV is saying for me too. Is it not correct?jjslegacy wrote: Tue Jul 23, 2019 8:28 pm I see that mkv is saying that 378 is the right one for redbox......
jjslegacy
really?WAYFLIX wrote: Wed Jul 24, 2019 3:08 pmMKV is rarely ever correct.GyroDragona wrote: Tue Jul 23, 2019 9:11 pmThat is what makeMKV is saying for me too. Is it not correct?jjslegacy wrote: Tue Jul 23, 2019 8:28 pm I see that mkv is saying that 378 is the right one for redbox......
I have never had it be wrong
Erazerhed
That's odd, yesterday I had no 378, but today I get the same final feature illustrated at the top. Thanks! (I'll keep both and wait till this is sorted out here though)
Erazerhed
Look over to the right side where each playlist shows it's # and it's segment order.Sush1988 wrote: Tue Jul 23, 2019 10:06 pmHow do you determine the numbers, When I open with MakeMKV I only see names.TheNid wrote: Tue Jul 23, 2019 9:58 pm My Redbox doesn't have a 00378.mpls but it does have a 00377.mpls. I use DVDFab and it chose 00401.mpls but is often wrong.
If possible can you please share the procedure how you are going to determine the correct playlist and Rip it from the disk.
Appreciate your Help.
EducateTheseKids
The 377 playlist looks to be correct. Thanks for sharing that. I had to create an account to thank you! I haven't watched the full movie but it got to the final credits and the after credit scene too. The time duration checks out compared to the disc.
jjslegacy
agreed on 377. I found an issue around 22minutes I think or so where 378 goes wrong but 377 seems okay
Fulgore99
can confirm 378 (the one makeMKV chooses) is wrong; sequence at about the 20 minute mark is out of order as previously posted. 377 is the correct playlist.
hvnphoto
Retail Version
Title information
Source file name: 00510.mpls
Duration: 2:01:02
Chapters count: 16
Segment count: 10
Segment map: 509,504,507,510,503,506,511,502,508,501
File name: Hellboy_t01.mkv
Title information
Duration: 2:01:02
Chapters count: 16
Segment count: 10
Techy87
It seems as though playlist 377 is accurate. I just ripped and watch the entire movie accurately. #Redbox BR
just_user
@Erazerhed - If there is a new BD, and it gives you few hundred (about 500 - The Kid) same looking playlists, how can you find out which one to select? Is there any writeup or sticky about it that you know?Erazerhed wrote: Wed Jul 24, 2019 10:18 pmLook over to the right side where each playlist shows it's # and it's segment order.Sush1988 wrote: Tue Jul 23, 2019 10:06 pmHow do you determine the numbers, When I open with MakeMKV I only see names.TheNid wrote: Tue Jul 23, 2019 9:58 pm My Redbox doesn't have a 00378.mpls but it does have a 00377.mpls. I use DVDFab and it chose 00401.mpls but is often wrong.
@mike_admin Also, as a feature request, it would be nice to be able to enter the playlist #, and get it selected. Scrolling through hundreds of same looking files to fish for the one is a bit overwhelming.
Erazerhed
A belated thank you. I had saved both and by consensus I will watch the 377. Not that it probably matters right? In all seriousness given the world as it is?
gyrfalcon
What do you do with the mpls playlist file exactly, do you utilize it in makeMKV? Also I'm looking at a full backup of 4K redbox hellboy and don't see the mpls files you're talking about.
You won't see the same mpls's on a UHD BD as you do on a regular BD. They're mastered differently.
gyrfalcon
That's what I figured and was going to edit my post but apparently I still have to have all my posts approved by a moderator.Woodstock wrote: Sun Aug 04, 2019 7:25 pm You won't see the same mpls's on a UHD BD as you do on a regular BD. They're mastered differently.
So how do you utilize the mpls playlist/menu? I've just been doing full backups/convert everything to mkv.
