Long Shot (U.S.A)
Steveredrum
Long Shot (U.S.A)
#1 Post by Steveredrum » Tue Jul 23, 2019 10:40 pm
Long Shot (U.S.A) Retail PLAYLIST Please
hvnphoto
Re: Long Shot (U.S.A)
#2 Post by hvnphoto » Tue Jul 23, 2019 10:49 pm
00373.MPLS
Steveredrum
#3 Post by Steveredrum » Tue Jul 23, 2019 11:13 pm
00373.MPLS
Thanks for your quick response
Shadowhwk
#4 Post by Shadowhwk » Wed Jul 24, 2019 12:43 am
00373.MPLS
Is determining the correct playlist as simple as using a tool like BDInfo? I've used it to check what you said is the correct playlist, and it shows the same 00373.MPLS as the first one in the list after analyzing the disc (ripped folder/iso).
While I appreciate the fast response as much as the OP, it would be nice to know how this is determined for other discs with similar playlist obfuscation.
Steveredrum
#5 Post by Steveredrum » Wed Jul 24, 2019 1:09 pm
00373.MPLS
To know how to find "Playlist Obfuscation/Screen Pass" you need to read "Jack The Lads TUT" on youtube that shows you how to find the correct
Playlists & the fake ones as well
hvnphoto
#6 Post by hvnphoto » Wed Jul 24, 2019 3:56 pm
00373.MPLS
I don't use BDInfo. I find the correct playlist manually and verify it by using AnyDVD HD. Maybe I should use BDInfo going forward.
ChrisCaPWN
#7 Post by ChrisCaPWN » Thu Jul 25, 2019 10:49 pm
Does anyone know the rental playlist? 00373.MPLS is not an option on the rental disc.
hvnphoto
#8 Post by hvnphoto » Fri Jul 26, 2019 4:11 pm
In case anyone wants the segment map for the retail version.
Title information
Source file name: 00373.mpls
Duration: 2:04:56
Chapters count: 16
Segment count: 14
Segment map: 503,512,505,504,515,511,519,502,509,517,513,508,507,501
File name: Long Shot_t123.mkv
Grisle
#9 Post by Grisle » Tue Jul 30, 2019 2:23 pm
Try 837
WAYFLIX
#10 Post by WAYFLIX » Tue Jul 30, 2019 4:01 pm
837.mpls is Redbox.
KENSAI
#11 Post by KENSAI » Tue Jul 30, 2019 8:14 pm
837.mpls is Redbox.
Thank you sir! :mrgreen:
johng
#12 Post by johng » Wed Jul 31, 2019 12:23 am
Is the rental version 837.mpls the same Segment map: 503,512,505,504,515,511,519,502,509,517,513,508,507,501 as the retail?
avenger09123
#13 Post by avenger09123 » Wed Jul 31, 2019 1:11 am
It looks like you are correct - they appear to be the same list.
jmjackson1
#14 Post by jmjackson1 » Wed Jul 31, 2019 2:06 am
Does anyone happen to have any other options? I rented my version from a family video and I do not have 373 or 837. Also all my segment maps start with 505 not 503. If anyone has any other info it would be appreciated.
Thank you
johng
#15 Post by johng » Wed Jul 31, 2019 4:45 am
I just got the Netflix version, and 837 doesn't seem to be correct as the segment map for that on the disc is:
505,517,512,514,516,510,501,506,509,502,519,503,518,515
there is also no 00373.mpls, any another ideas?
