Long Shot (U.S.A)
Steveredrum
Long Shot (U.S.A)
Post by Steveredrum »
Long Shot (U.S.A) Retail PLAYLIST Please
hvnphoto
Re: Long Shot (U.S.A)
Post by hvnphoto »
00373.MPLS
Steveredrum
hvnphoto wrote:
Tue Jul 23, 2019 10:49 pm
00373.MPLS
Thanks for your quick response
Shadowhwk
Post by Shadowhwk »
00373.MPLS
Is determining the correct playlist as simple as using a tool like BDInfo? I've used it to check what you said is the correct playlist, and it shows the same 00373.MPLS as the first one in the list after analyzing the disc (ripped folder/iso).
While I appreciate the fast response as much as the OP, it would be nice to know how this is determined for other discs with similar playlist obfuscation.
Steveredrum
Shadowhwk wrote:
Wed Jul 24, 2019 12:43 am
00373.MPLS
To know how to find "Playlist Obfuscation/Screen Pass" you need to read "Jack The Lads TUT" on youtube that shows you how to find the correct
Playlists & the fake ones as well
hvnphoto
Post by hvnphoto »
00373.MPLS
I don't use BDInfo. I find the correct playlist manually and verify it by using AnyDVD HD. Maybe I should use BDInfo going forward.
ChrisCaPWN
Post by ChrisCaPWN »
Does anyone know the rental playlist? 00373.MPLS is not an option on the rental disc.
hvnphoto
Post by hvnphoto »
In case anyone wants the segment map for the retail version.
Title information
Source file name: 00373.mpls
Duration: 2:04:56
Chapters count: 16
Segment count: 14
Segment map: 503,512,505,504,515,511,519,502,509,517,513,508,507,501
File name: Long Shot_t123.mkv
Grisle
Post by Grisle »
ChrisCaPWN wrote:
Thu Jul 25, 2019 10:49 pm
Try 837
WAYFLIX
Post by WAYFLIX »
837.mpls is Redbox.
KENSAI
Post by KENSAI »
WAYFLIX wrote:
Tue Jul 30, 2019 4:01 pm
837.mpls is Redbox.
Thank you sir! :mrgreen:
johng
Post by johng »
Is the rental version 837.mpls the same Segment map: 503,512,505,504,515,511,519,502,509,517,513,508,507,501 as the retail?
avenger09123
Post by avenger09123 »
It looks like you are correct - they appear to be the same list.
jmjackson1
Post by jmjackson1 »
Does anyone happen to have any other options? I rented my version from a family video and I do not have 373 or 837. Also all my segment maps start with 505 not 503. If anyone has any other info it would be appreciated.
Thank you
johng
Post by johng »
I just got the Netflix version, and 837 doesn't seem to be correct as the segment map for that on the disc is:
505,517,512,514,516,510,501,506,509,502,519,503,518,515
there is also no 00373.mpls, any another ideas?
