The Last Emperor 3D (Italy) Failed to open disk
jahtv
#1 Post by jahtv » Mon Dec 12, 2016 9:27 pm
I tried to rip The Last Emperor 3D, on OS X and on Windows and in both it failed to open, here is the log from OS X.
What can be wrong?
MakeMKV v1.10.3 darwin(x86-release) started
Debug logging enabled, log will be saved as /Users/jahedderich/MakeMKV_log.txt
Optical drive "BD-RE PIONEER BD-RW BDR-XU03 1.03" opened in DASPI v1.5 mode.
Optical drive "BD-ROM PLEXTOR BDDVDR PX-B310U 1.07" opened in DASPI v1.5 mode.
DEBUG: Code 0 at _Etls=q$@X"`+H[_l:29393953
DEBUG: Code 0 at N^f;\Tw0WtF(rz:121262578
DEBUG: Code 0 at >6aFX8OWcI' pPgo:213135044
Title #00000.mpls has length of 108 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00021.mpls has length of 14 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00021.mpls(1) has length of 13 seconds which is less than minimum title length of 600 seconds and was therefore skipped
DEBUG: Code 0 at z+iL?FUh"E>A$baYL:213132583
DEBUG: Code 0 at z+iL?FUh"E>A$baYL:121263797
Title #00002.m2ts has length of 6 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00021.m2ts has length of 55 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00000.m2ts has length of 52 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00018.m2ts has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00015.m2ts has length of 6 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00011.m2ts has length of 14 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00007.m2ts has length of 15 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00006.m2ts has length of 10 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00009.m2ts has length of 16 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00001.m2ts has length of 7 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Title #00008.m2ts has length of 15 seconds which is less than minimum title length of 600 seconds and was therefore skipped
Re: The Last Emperor 3D (Italy) Failed to open disk
#2 Post by Woodstock » Tue Dec 13, 2016 2:05 am
It doesn't seem that MakeMKV found any titles that were longer than your 10 minute minimum, but that seems VERY strange, even if you were looking at the "extras" disk.
I would recommend following the FAQ listed in my signature to send the requested files to support@makemkv.com, for Mike to look at. The debug messages usually mean that something unexpected was found, which can be caused by a dirty disk, but that's uncertain, because there were no actual error messages about not being able to read the disk... Just that what WAS read was unexpected.
jahtv
#3 Post by jahtv » Tue Dec 13, 2016 2:45 am
Thanks for your reply, the disks opens fine in DVDfab and in Leawo Prof Media, the disk is the movie disk, no extra disks on the package and I have sent the files requested for Aquamarine Blu-Ray and The Last Emperor 3D to support@makemkv.com and never got a reply or the disks working at a later date after an Update. I am a Paying customer and I expect at least a reply.
Thanks for your help
JAH
Woodstock wrote:It doesn't seem that MakeMKV found any titles that were longer than your 10 minute minimum, but that seems VERY strange, even if you were looking at the "extras" disk.
FingersDLP
#4 Post by FingersDLP » Thu Oct 25, 2018 1:51 am
FYI, I too purchased this title from Amazon Italy. Same issue. I can reduce the time to like 10 seconds to get some titles but the longest is like 00:01:28 so very short. Will hope for a future fix. Log like above.
bradleyrealtor
#5 Post by bradleyrealtor » Wed Jul 03, 2019 8:06 pm
I have an issue with this disc as well. Mac, MakeMkv 1.14.4, Opens disc and shows only one file of 283.2 mb which copies fine but it's just the title.
Anyone?
This is the Italian 3d disc.
Last Emperor.jpg (562.67 KiB) Viewed 45447 times
bobmorlock
#6 Post by bobmorlock » Tue Jul 09, 2019 7:56 pm
I'm having the same issue.
The only the 282MB header video is located.
But the disc does contain 38GB and 11GB m2ts files under BDMV/STREAM. Copying all the content to a HD and trying to open various content files with makemkv didn't locate those files.
JREkiwi
#7 Post by JREkiwi » Wed Jul 24, 2019 8:09 am
I have the same issue, so I've submitted a support request.
John
bradleyrealtor
#8 Post by bradleyrealtor » Wed Jul 24, 2019 11:53 pm
thanks, John
bobmorlock
#9 Post by bobmorlock » Fri Jul 26, 2019 3:20 pm
Thanks John.
If this gets addressed, how would be this happen? A new version of the software needs to be rolled out?
juanitobanana
#10 Post by juanitobanana » Wed Mar 18, 2020 2:29 am
I have the same issue. It seems like MovieRescuer is able to see the movie and extract it, however it does not have the 3D part. John, where is the support request? Maybe I can post this info there..
#11 Post by Woodstock » Wed Mar 18, 2020 2:32 am
This topic is almost 4 years old. Most likely errors now would be from a dirty disk, unless you're using a version of MakeMKV from 2016.
juanitobanana
#12 Post by juanitobanana » Wed Mar 18, 2020 9:46 am
My disc is pristine new, just opened form the case. I have the very latest makemkv, 1.15.0, so no, the issue is still there unfortunately
juanitobanana
#13 Post by juanitobanana » Wed Mar 18, 2020 9:47 am
you can also see how many people posted this same issue just 6 months ago
#14 Post by Woodstock » Wed Mar 18, 2020 12:52 pm
And the advice given in the second message still applies; follow the FAQ link in my signature and submit the requested information to the program author, for him to look at it.
jahtv
#15 Post by jahtv » Wed Mar 18, 2020 1:04 pm
I did, on 2016.
