Hellboy (2019) - Which Playlist?
WAYFLIX
Re: Hellboy (2019) - Which Playlist?
Post by WAYFLIX » Wed Jul 24, 2019 3:07 pm
MAJWoody wrote: Tue Jul 23, 2019 10:40 pm I tested 377 and I don't think that is the right one.... played side by side with disc (Leawo BR player) and did not match up 100%
Using the filter process log method this is the one my blu-ray player chooses to play. I will have to watch it through to be sure but this method has never steered me wrong with lions gate films.
WAYFLIX
Post by WAYFLIX » Wed Jul 24, 2019 3:08 pm
GyroDragona wrote: Tue Jul 23, 2019 9:11 pm
jjslegacy wrote: Tue Jul 23, 2019 8:28 pm I see that mkv is saying that 378 is the right one for redbox......
That is what makeMKV is saying for me too. Is it not correct?
MKV is rarely ever correct.
jjslegacy
Post by jjslegacy » Wed Jul 24, 2019 3:37 pm
WAYFLIX wrote: Wed Jul 24, 2019 3:08 pm
really?
I have never had it be wrong
Erazerhed
Post by Erazerhed » Wed Jul 24, 2019 10:08 pm
That's odd, yesterday I had no 378, but today I get the same final feature illustrated at the top. Thanks! (I'll keep both and wait till this is sorted out here though)
Erazerhed
Post by Erazerhed » Wed Jul 24, 2019 10:18 pm
Sush1988 wrote: Tue Jul 23, 2019 10:06 pm
TheNid wrote: Tue Jul 23, 2019 9:58 pm My Redbox doesn't have a 00378.mpls but it does have a 00377.mpls. I use DVDFab and it chose 00401.mpls but is often wrong.
How do you determine the numbers, When I open with MakeMKV I only see names.
If possible can you please share the procedure how you are going to determine the correct playlist and Rip it from the disk.
Appreciate your Help.
Look over to the right side where each playlist shows it's # and it's segment order.
EducateTheseKids
Post by EducateTheseKids » Thu Jul 25, 2019 2:16 am
WAYFLIX wrote: Tue Jul 23, 2019 1:42 pm
hvnphoto wrote: Mon Jul 22, 2019 5:19 pm Correct playlist for retail is 00510.mpls.
sharpie00 wrote: Sat Jul 20, 2019 12:56 am hey guys,
so there's a bajillion titles on the disc; just wondering which one is the right one for the retail version of Hellboy (2019).
thanks in advance. :D
00377.mpls for redbox
The 377 playlist looks to be correct. Thanks for sharing that. I had to create an account to thank you! I haven't watched the full movie but it got to the final credits and the after credit scene too. The time duration checks out compared to the disc.
jjslegacy
Post by jjslegacy » Thu Jul 25, 2019 4:44 pm
agreed on 377. I found an issue around 22minutes I think or so where 378 goes wrong but 377 seems okay
Fulgore99
Post by Fulgore99 » Fri Jul 26, 2019 3:56 am
can confirm 378 (the one makeMKV chooses) is wrong; sequence at about the 20 minute mark is out of order as previously posted. 377 is the correct playlist.
hvnphoto
Post by hvnphoto » Fri Jul 26, 2019 4:18 pm
Retail Version
Title information
Source file name: 00510.mpls
Duration: 2:01:02
Chapters count: 16
Segment count: 10
Segment map: 509,504,507,510,503,506,511,502,508,501
File name: Hellboy_t01.mkv
Techy87
Post by Techy87 » Sat Aug 03, 2019 12:12 am
It seems as though playlist 377 is accurate. I just ripped and watch the entire movie accurately. #Redbox BR
just_user
Post by just_user » Sat Aug 03, 2019 12:41 am
Erazerhed wrote: Wed Jul 24, 2019 10:18 pm
@Erazerhed - If there is a new BD, and it gives you few hundred (about 500 - The Kid) same looking playlists, how can you find out which one to select? Is there any writeup or sticky about it that you know?
@mike_admin Also, as a feature request, it would be nice to be able to enter the playlist #, and get it selected. Scrolling through hundreds of same looking files to fish for the one is a bit overwhelming.
Erazerhed
Post by Erazerhed » Sat Aug 03, 2019 3:00 am
A belated thank you. I had saved both and by consensus I will watch the 377. Not that it probably matters right? In all seriousness given the world as it is?
gyrfalcon
Post by gyrfalcon » Sun Aug 04, 2019 4:52 pm
What do you do with the mpls playlist file exactly, do you utilize it in makeMKV? Also I'm looking at a full backup of 4K redbox hellboy and don't see the mpls files you're talking about.
Post by Woodstock » Sun Aug 04, 2019 7:25 pm
You won't see the same mpls's on a UHD BD as you do on a regular BD. They're mastered differently.
gyrfalcon
Post by gyrfalcon » Sun Aug 04, 2019 11:10 pm
Woodstock wrote: Sun Aug 04, 2019 7:25 pm You won't see the same mpls's on a UHD BD as you do on a regular BD. They're mastered differently.
That's what I figured and was going to edit my post but apparently I still have to have all my posts approved by a moderator.
So how do you utilize the mpls playlist/menu? I've just been doing full backups/convert everything to mkv.
