Submitted my dump file for this title. Hoping it MakeMKV gets updated soon!
The Doors Remastered 4K Key
stuckinkodiagain
Re: The Doors Remastered 4K Key
Submitted my dump as well. Thanks to Mike!
hedcase
Looks like the key is available. Thanks!
mstephens7
Greetings. I just got this disc and my drive keeps trying to load it and then spits it out. Could I have a bad 4k disc? My Make MKV is up to date. Thanks for any thoughts in advance.
What drive do you havemstephens7 wrote: Mon Jul 29, 2019 10:03 pm Greetings. I just got this disc and my drive keeps trying to load it and then spits it out. Could I have a bad 4k disc? My Make MKV is up to date. Thanks for any thoughts in advance.
What firmware do you have
Do other uhd disks work
What is the build date of your drive
mstephens7
Apologies for such bad form asking a question. I should have included that info:
ASUS BW-16D1X-U on a new iMac (https://www.asus.com/us/Optical-Drives- ... /overview/)
I cannot locate what firmware it has - ASUS site has no updates for Mac
Other UHD have ripped just fine. Just did Die Hard 4k
Cannot locate the date.
I hope this helps-
M.
I hope this helps-
M.
the ASUS BW-16D1X-U does not support UHD disks so you either have the model confused or you confused the die hard diskmstephens7 wrote: Mon Jul 29, 2019 11:28 pm Apologies for such bad form asking a question. I should have included that info:
I hope this helps-
M.
What Billy said - that Asus cannot read UHD disks. I tried... and ended up giving it to someone who has no need for UHD.
mstephens7
Sincere apologies! I was a bit confused. Thanks for your help.
