Alita: Battle Angel 4K Correct Playlist?
sharpie00
Post by sharpie00 »
Hey guys,
Just got the retail version of Alita: Battle Angel 4K.
Is it safe to assume the correct playlist is 00800.mpls?
deathtical
Re: Alita: Battle Angel 4K Correct Playlist?
Post by deathtical »
I am also interested in this.
deathtical
I just went ahead and ripped 800 and it appears to be correct. This is for the US UHD 4K disc from Amazon (came with 3D and Blu Ray). I have ripped both the 4K and BR and both seem to be 800.
Good Luck!
sharpie00
Post by sharpie00 »
deathtical wrote: Tue Jul 23, 2019 11:11 pm I just went ahead and ripped 800 and it appears to be correct. This is for the US UHD 4K disc from Amazon (came with 3D and Blu Ray). I have ripped both the 4K and BR and both seem to be 800.
Good Luck!
Thank you! :)
Someguy1234
Post by Someguy1234 »
I've tried to rip this 800 and numerous other playlists and I keep getting corrupt data and attempts at workarounds. The disc is perfectly clean though. Anyone else having this problem at all?
stuckinkodiagain
Post by stuckinkodiagain »
Someguy1234 wrote: Wed Jul 24, 2019 6:41 am I've tried to rip this 800 and numerous other playlists and I keep getting corrupt data and attempts at workarounds. The disc is perfectly clean though. Anyone else having this problem at all?
No problems here at all. But as others might suggest, even though a disc looks perfectly clean, it’s worth cleaning and trying again. That’s solved my issue in the past.
But I’ve also had two cases - one of them was “The Phantom Thread” - where I had what looked to be a clean disc and wouldn’t copy, then I cleaned it and it still wouldn’t copy, and finally I just turned it in for a new disc and it copied just fine. (With both the original disc and it’s replacement, however, they played just fine in my UHD player... MakeMKV, though, only liked the second replacement disc.)
UHD blu-rays can be really finicky. 9 times out of 10, MakeMKV reads them just fine. But you’ll get the odd one that’s just a pain in the ass.
blurayfan2019
Post by blurayfan2019 »
Yes. I chose 00800.MPLS. It was at the top of the list and I played all segments from Segment map: 687,688,674,689 (those are m2ts files) to verify. Worked perfectly.
buggystick
Post by buggystick »
So I recently bought Alita: Battle Angel from Amazon and for some reason the disc is not UHD. It has both the bluray and the 3D disk, but makemkv isn't showing a 4K playlist, just 1080p. This disk is brand new, just took the shrink wrap off and it says "4K UltraHD" at the top...
Did I somehow get a non UHD disk in a UHD box?
Normally you'll have two separate disks - one UHD, the other HD (regular Bluray). This title is supposed to have 3 disks in the package, according to Amazon. Only one of them is UHD, though.
buggystick
Wow.... I feel like an idiot. It was hiding behind the movies anywhere flyer. Thanks for pointing out it had three disks ... smh
What? You didn't IMMEDIATELY pull out the special code for downloading the DRM-infected version that tracks where you watched their movie?!? What kind of consumer are you?!?
Supposedly, it's legal to sell off those access codes... Redbox has been doing it for some time.
crazyguy
Post by crazyguy »
Where did you guys get the decryption key?
st4evr
Post by st4evr »
crazyguy wrote: Wed Aug 14, 2019 4:22 am Where did you guys get the decryption key?
Forum search function works. Discussed hundreds of times already.
https://www.makemkv.com/forum/viewtopic ... tic#p76840
https://www.makemkv.com/forum/search.ph ... =Automatic
https://www.makemkv.com/forum/search.ph ... s=Hash+key
lwndow
Post by lwndow »
buggystick wrote: Sat Aug 10, 2019 4:26 am So I recently bought Alita: Battle Angel from Amazon and for some reason the disc is not UHD. It has both the bluray and the 3D disk, but makemkv isn't showing a 4K playlist, just 1080p. This disk is brand new, just took the shrink wrap off and it says "4K UltraHD" at the top...
How did you get the light descriptions to show up in parens next to the titles? Very cool.
blurayfan2019
If you're not getting that it is probably a Java version problem. The same thing happened to me and others. See Re: Error with JRE on bluRay Eighth grade to fix it.
