The Doors Remastered 4K Key
hedcase
#1 Post by hedcase » Tue Jul 23, 2019 8:27 pm
Submitted my dump file for this title. Hoping it MakeMKV gets updated soon!
stuckinkodiagain
Re: The Doors Remastered 4K Key
#2 Post by stuckinkodiagain » Wed Jul 24, 2019 2:52 am
Submitted my dump as well. Thanks to Mike!
hedcase
#3 Post by hedcase » Sun Jul 28, 2019 6:05 pm
Looks like the key is available. Thanks!
mstephens7
#4 Post by mstephens7 » Mon Jul 29, 2019 10:03 pm
Greetings. I just got this disc and my drive keeps trying to load it and then spits it out. Could I have a bad 4k disc? My Make MKV is up to date. Thanks for any thoughts in advance.
#5 Post by Billycar11 » Mon Jul 29, 2019 10:16 pm
mstephens7 wrote: Mon Jul 29, 2019 10:03 pm Greetings. I just got this disc and my drive keeps trying to load it and then spits it out. Could I have a bad 4k disc? My Make MKV is up to date. Thanks for any thoughts in advance.
What drive do you have
What firmware do you have
Do other uhd disks work
What is the build date of your drive
mstephens7
#6 Post by mstephens7 » Mon Jul 29, 2019 11:28 pm
Apologies for such bad form asking a question. I should have included that info:
ASUS BW-16D1X-U on a new iMac (https://www.asus.com/us/Optical-Drives- ... /overview/)
I cannot locate what firmware it has - ASUS site has no updates for Mac
Other UHD have ripped just fine. Just did Die Hard 4k
Cannot locate the date.
I hope this helps-
M.
#7 Post by Billycar11 » Tue Jul 30, 2019 2:47 am
mstephens7 wrote: Mon Jul 29, 2019 11:28 pm Apologies for such bad form asking a question. I should have included that info:
I hope this helps-
M.
the ASUS BW-16D1X-U does not support UHD disks so you either have the model confused or you confused the die hard disk
#8 Post by Woodstock » Tue Jul 30, 2019 2:05 pm
What Billy said - that Asus cannot read UHD disks. I tried... and ended up giving it to someone who has no need for UHD.
mstephens7
#9 Post by mstephens7 » Tue Jul 30, 2019 3:14 pm
Sincere apologies! I was a bit confused. Thanks for your help.
