bl4ck
Post
by bl4ck » Tue Jul 23, 2019 9:17 am
Hello
My first problem after copy many discs
Disc Information
Label: SOLOMON KANE
Timestamp: 2010-05-31 09:13:50
Data capacity: 32.41 Gb
Disc type: BD-ROM
Number of layers: 2
MakeMKV v1.14.4 linux(x64-release) started
Backing up disc into folder "/home/pro/backup/SOLOMON KANE"
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.10' at offset '917504'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/AACS/ContentRevocation.lst' at offset '106496'
Encountered 38 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup failed
What can be the problem? someone know?
Thank you for help.
Post
by MartyMcNuts » Tue Jul 23, 2019 9:47 am
bl4ck wrote: Tue Jul 23, 2019 9:17 am
Hello
Disc Information
Label: SOLOMON KANE
Disc type: BD-ROM
Number of layers: 2
Backup failed
Thank you for help.
The first thing to try is cleaning the disc (even if it looks spotless!) Hopefully that will solve your issue.
** NEW Single Drive Flasher ** available worldwide!
https://payhip.com/b/MyeJ9
bl4ck
Post
by bl4ck » Tue Jul 23, 2019 9:49 am
I tried many times
problem is physical? with disc?
