Bluray Drive Stopped reading Blurays and 4k blurays help needed asap thanks
SPOOK101
Re: Bluray Drive Stopped reading Blurays and 4k blurays help needed asap thanks
We need some help to help you... Did you recently try playing or ripping a BD with a version of AACS newer than v70? In your MakeMKV data directory, are there any files that start with MKB_v or MKB2_v and a number larger than 70?
Version 71 of AACS has been reported "in the wild", and some drives are treating is as a "revoking release", disabling MakeMKV access, pending a new version being released. If your MakeMKV data directory has a MKB file for v71 or later, please send it to svq@makemkv.com so that Mike can update support for it.
jonghotti
This happens relatively frequently yes? I keep getting sporatic reports of "2K" blu rays and DVDs just not ripping at all suddenly and I know I test each drive with a 4K (twice) 2K and standard DVD.Woodstock wrote: Sun Jul 21, 2019 5:35 pm We need some help to help you... Did you recently try playing or ripping a BD with a version of AACS newer than v70? In your MakeMKV data directory, are there any files that start with MKB_v or MKB2_v and a number larger than 70?
So bear with me version 71 of aacs is only found on 4k UHD blu rays or any blu ray? And would the act of reading one shut down ripping entirely on a drive?
Thank you sir.
Some AACS versions have new key revocation tables in them. If a drive loads one of them (even if you don't play it), the key revocation table in the drive is updated, and the revoked key (in this case, MakeMKV's) becomes invalid for accessing any BD content, including UHD.
LibreDrive tells compatible drives to ignore that table, so it won't affect people using LD mode. But it does affect drives those drives in non-LD mode.
jonghotti
Thank you very much!Woodstock wrote: Mon Jul 22, 2019 1:06 pm Some AACS versions have new key revocation tables in them. If a drive loads one of them (even if you don't play it), the key revocation table in the drive is updated, and the revoked key (in this case, MakeMKV's) becomes invalid for accessing any BD content, including UHD.
SPOOK101
no idea all i know is i ripped 1 4k bluray 2 weeks ago and now it wont detect any 4k blurays or normal bluray but will only dvds in both makemkv and deuhd for 4k blurays
