Donpoku
Post by Donpoku »
Hi peeps, anyone know if this will work on 4k fire TV stick Dolby vision via NAS on lg c6 TV? Thank you.
Redhawk2000
Post by Redhawk2000 »
Grencola wrote: Wed Jul 03, 2019 2:32 pm
Redhawk2000 wrote: Sun Jun 30, 2019 12:08 am Anyone have any idea if the newer lg c9 with HDMI 2.1 and eARC would be able to play full DV disc rips via USB or Ethernet and then output (via eARC) lossless audio to a receiver?
I ask because I just ordered a c8 on sale but would cancel it if the above was a maybe.
You'll only get HDR10 if you try this. You either need an Oppo uhd-bd player (or its clone), or a converted MP4 to get Dolby Vision, the latter only has lossy audio. The Matroska devs are working on an MKV update to support Dolby Vision, but there's no ETA as of yet.
Thanks. Especially the info in the last sentence. Glad to hear.
cyperous
Post by cyperous »
cyperous wrote: Tue Jun 18, 2019 2:16 am
sm0ke83 wrote: Sat May 25, 2019 7:04 pm
cyperous wrote: Fri May 17, 2019 9:05 pm Found some more interesting info that might help.
I did find out that seeking is working but it is very cpu intensive and on my 6 core 12 thread machine, it maxes the cpus to 100% and takes over a minute for the seek to happen. The TV is probably giving up after a short period and just starts over from the beginning.
I tried doing some research around 10bit 265 and mp4's and it turns out that mp4muxer does not write the file correctly that would build a resulted file that is seeable under a normal conditions.
For clarification here are the commands I ran to build comparison files, NOTE: these are all without dv files.
mp4muxer -i video.265 -i audio.ac3 -o temp_mp4muxer.mp4
mp4box -add video.265 -add audio.ac3 -new temp_mp4box.mp4
ffmpeg -i video.265 -i audio.ac3 -c copy -map 0:0 -map 1:0 temp_ffmpeg.mp4
ffmpeg and mp4box produce a seekable file whereas mp4muxer does not.
I would also like to note that all three of these command produce different byte codes.
Overlooked this... need to look into this too also I think...
Yeah, I'm glad someone else noticed.
For now I'm just caching the DV Layer so I can potentially fix the seeking later without having to re-rip all my DV titles.
I think I have solved the mystery of re-encoded DV rips not being able to seek effiently.
I was playing around with the raw streams and noticed that seeking was fine but not after re-encoding the hdr10 portion of the stream.
After playing around with several options, I found that adding the following option to handbrake solved my seeking issues.
uhd-bd=1
This adds uhd compatibility. There is one catch this option forces crf. Which is fine for me cause I was already using it to re-encode. I compared my hdr10 file before and after using this option and it only increased the file size by 1G.
Hopefully this helps others who are re-encoding.
Alldu
Post by Alldu »
Grencola wrote: Wed Jul 03, 2019 1:22 pm
Alldu wrote: Wed Jul 03, 2019 10:19 am Hmm, sorry, don't want to be "that guy", but it still isn't working... I uploaded the subs you've shared to the folder where m2ts file was and renamed it, still same error...
put it in the same folder as your dv mp4. make the .srt and the .mp4 the exact same filename. play your mp4 and you will get subs. might have to enable them during playback depending on device.
Duh, finally I understand what you meant :D Thanks again, you rule! All works like a charm!
Donpoku
Post by Donpoku »
powdeau wrote: Thu Jun 20, 2019 2:39 pm
murrayit wrote: Tue Jun 18, 2019 4:43 am
powdeau wrote: Fri May 17, 2019 1:21 am
I have LG C7 and I also have these artifacts in some movies. It is not because of DV or a HDD, but because of the player in TV. It cause artifacts also on the remuxes or on the m2ts files from ISO. It's too bad that LG didn't fix it on new model (also someone should try it on C7). I fixed this by buying Sony X700 where it works fine.
I just have an issue there with DV. Sometimes, when there is a change of the shot in the movie, the screen flashes for a 1 frame. If someone know how to fix this, it would be awesome. I have this problem just with DV.
I also experience these artifacts on OLED B7. For example in Captain America Civil War or Us or many other titles. It has nothing to do with mp4 DV discs though...
Any solutions for these? Or any suggested player which has the same picture quality as well as DV playback (I can't afford Oppo...)
Yes, the Sony X700.
Hello, lg c6 owner here, will Sony X700 get rid of all the green tint movies and does it play 3d ISO? Thanks.
daddy
Post by daddy »
From what i know, the C9 is unable to play .iso files.
The C9 can play m2ts files from a BDMV/STREAM folder, but they will play only in hdr10.
So, the only way to get DV from a file is to make a mp4 file with the mp4muxer from DolbyLaboratories.
You can't have DV and lossless audio.
The mp4 file supports only Dolby Digital (AC-3), Dolby Digital Plus (E-AC-3), and Dolby AC-4.
tr000
Post by tr000 »
I have a TCL Dolby Vision TV. Here are some files that play.
Complete name                            : F:\Demos\Dolby OnOff.ts
File size                                : 678 MiB
Duration                                 : 2 min 17 s
Overall bit rate mode                    : Constant
Overall bit rate                         : 41.5 Mb/s
Video
Menu ID                                  : 2 (0x2)
Format profile                           : Main 10@L5.1@Main
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Bit rate                                 : 38.9 Mb/s
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.196
Stream size                              : 636 MiB (94%)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : 135
Duration                                 : 2 min 16 s
Bit rate                                 : 504 kb/s
Stream size                              : 8.20 MiB (1%)
Complexity index                         : 16
Number of dynamic objects                : 15
Complete name                            : F:\Demos\food.60.dm1_U30000_mz.ts
File size                                : 287 MiB
Duration                                 : 1 min 16 s
Overall bit rate                         : 31.6 Mb/s
Video
Menu ID                                  : 2 (0x2)
Bit rate                                 : 29.4 Mb/s
Frame rate                               : 60.000 FPS
Bits/(Pixel*Frame)                       : 0.059
Stream size                              : 266 MiB (93%)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 135
Duration                                 : 1 min 15 s
Stream size                              : 5.77 MiB (2%)
General
Complete name                            : F:\Demos\NASA (Dolby Vision).mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 510 MiB
Duration                                 : 2 min 23 s
Overall bit rate                         : 29.9 Mb/s
Encoded date                             : UTC 2017-04-13 22:51:30
Tagged date                              : UTC 2017-04-13 22:51:30
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.09, BL+RPU
Bit rate                                 : 29.3 Mb/s
Frame rate                               : 59.940 (60000/1001) FPS
Stream size                              : 499 MiB (98%)
Audio
Format                                   : E-AC-3 JOC
Codec ID                                 : ec-3
Duration                                 : 2 min 22 s
Bit depth                                : 16 bits
Stream size                              : 10.9 MiB (2%)
Complexity index                         : 14
Number of dynamic objects                : 13
This sample video someone on Reddit uploaded also works, though with no audio.
General
Complete name                            : F:\Batman vs. Superman_cutted.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 449 MiB
Duration                                 : 2 min 20 s
Overall bit rate                         : 26.8 Mb/s
Video
Menu ID                                  : 2 (0x2)
Format profile                           : Main 10@L5@Main
Duration                                 : 2 min 21 s
Bit rate                                 : 25.1 Mb/s
Bits/(Pixel*Frame)                       : 0.126
Stream size                              : 422 MiB (94%)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 6
Delay relative to video                  : -486 ms
Stream size                              : 10.7 MiB (2%)
Language                                 : French
Complexity index                         : 12
FIles made using the method in this thread do not work. They start with a green screen then I can see the video, but with horribly distorted colors.
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Duration                                 : 1 min 0 s
Bit rate                                 : 44.5 Mb/s
Bits/(Pixel*Frame)                       : 0.224
Stream size                              : 322 MiB (89%)
Title                                    : Transformers.2007.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT
Video #2
Bit rate                                 : 4 903 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.099
Stream size                              : 35.4 MiB (10%)
Audio
Codec ID                                 : A_AC3
Bit depth                                : 16 bits
Stream size                              : 4.63 MiB (1%)
Any ideas on how to get remuxed MKVs with two video tracks into one DV track that plays on my TV?
tr000 wrote: Fri Jul 19, 2019 11:33 pm I have a TCL Dolby Vision TV. Here are some files that play.
File size                                : 678 MiB
Video
Menu ID                                  : 2 (0x2)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 135
Bit rate                                 : 504 kb/s
File size                                : 287 MiB
Video
Menu ID                                  : 2 (0x2)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 135
General
File size                                : 510 MiB
Video
Audio
Format                                   : E-AC-3 JOC
Codec ID                                 : ec-3
Bit depth                                : 16 bits
General
Format                                   : BDAV
File size                                : 449 MiB
Video
Menu ID                                  : 2 (0x2)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 6
Language                                 : French
Video #1
Video #2
Audio
Codec ID                                 : A_AC3
Bit depth                                : 16 bits
You could try CloneBD.
tr000
Post by tr000 »
MartyMcNuts wrote: Sat Jul 20, 2019 1:07 am You could try CloneBD.
Does that work with .mkv files? I was under the impression that it required a full Blu Ray with BDMV folder structure intact and then converts it to a DV MP4, like DVDFab.
tr000 wrote: Sat Jul 20, 2019 4:18 am
You need either disc/iso/folder to use CloneBD
tr000
Post by tr000 »
MartyMcNuts wrote: Sat Jul 20, 2019 6:40 am
That's what I thought. Guess I should get some full Blu-rays then.
tr000 wrote: Sat Jul 20, 2019 7:11 am
Also, DV does not currently work in the MKV container.
daddy
Post by daddy »
I dont know about the cloneBD method, but here is the one i use and that work.
Exemple : To make a DV version of Alita Battle Angel, with French and English audio.
1/ BDinfo => to scan for the m2ts files that you have to join to demux the ISO/BDMV
2/ tsMuxeR GUI 2.6.12 => to demux the tracks you want
note:
At the end of the demux stage and to make it easier, i rename the files:
- for the HDR10 => bl.hevc
- for the DV layer => el.hevc
- the french audio => audio_fr.dts
- and english audio => audio_en.ac3
For the english track, i directly downconvert TrueHD to ac3, so there is no more work to do on english file.
So now i have: audio_fr.dts and audio_en.ac3
3/ eac3to => to convert audio file to codec supported by mp4 (e-ac3 or ac3)
As the audio_fr file is in dts, i need to convert it to ac3.
eac3to.exe audio_fr.dts audio.ac3 -core -640
4/ mp4muxer_64bits => to make the DV mp4 file
Now, all the files are in a format supported by the mp4 container.
I can make the DV mp4 file.
mp4muxer_64bits.exe --dv-profile 7 -i bl.hevc -i el.hevc -i audio_fr.ac3 --media-lang fre -i audio_en.ac3 --media-lang eng -o DV-Movie.mp4
note:
At the end you can rename the DV-Movie.mp4 file. For exemple, Alita, Battle Angel [FR ac3][EN ac3][4k][DV].mp4 :wink:
First audio track will be played by default.
On LG C7, when you select the second track, you lose the sound (LG bug?), but if you go back 15 seconds, then it works and you have the sound of the second track.
here s the nfo of the produced file
Général
Nom complet                              : C:\ESD\Alita, Battle Angel [FR ac3][EN ac3][4k][DV].mp4
Profil du format                         : Base Media / Version 2
Identifiant du codec                     : mp42 (mp42/dby1/isom)
Taille du fichier                        : 38,1 Gio
Durée                                    : 2 h 1 min
Débit global moyen                       : 44,8 Mb/s
Date d'encodage                          : UTC 2019-07-20 08:34:09
Date de marquage                         : UTC 2019-07-20 08:34:09
Vidéo #1
Profil du format                         : Main 10@L5.1@High
HDR_Format/String                        : SMPTE ST 2094 App 4, Version 1, HDR10+ Profile A compatible
Identifiant du codec                     : hev1
Identifiant du codec/Info                : High Efficiency Video Coding
Durée                                    : 2 h 1 min
Débit                                    : 41,4 Mb/s
Largeur                                  : 3 840 pixels
Hauteur                                  : 2 160 pixels
Format à l'écran                         : 16/9
Type d'images/s                          : Constant
Images par seconde                       : 23,976 (24000/1001) Im/s
Espace de couleurs                       : YUV
Sous-échantillonnage de la chrominance   : 4:2:0 (Type 2)
Profondeur des couleurs                  : 10 bits
Bits/(Pixel*Image)                       : 0.208
Taille du flux                           : 35,2 Gio (92%)
Default                                  : Non
Gamme de couleurs                        : Limited
Coordonnées de chromaticité              : BT.2020
Caractéristiques du transfert            : PQ
Coefficients de la matrice               : BT.2020 non-constant
MasteringDisplay_ColorPrimaries          : Display P3
MasteringDisplay_Luminance               : min: 0.0001 cd/m2, max: 1000 cd/m2
MaxCLL                                   : 233 cd/m2
MaxFALL                                  : 63 cd/m2
Codec configuration box                  : hvcC
Vidéo #2
HDR_Format/String                        : Dolby Vision, Version 1.0, dvhe.07.06, EL+RPU / SMPTE ST 2086, HDR10 compatible
Identifiant du codec                     : dvhe
Identifiant du codec/Info                : High Efficiency Video Coding with Dolby Vision
Durée                                    : 2 h 1 min
Débit                                    : 2 135 kb/s
Largeur                                  : 1 920 pixels
Hauteur                                  : 1 080 pixels
Bits/(Pixel*Image)                       : 0.043
Taille du flux                           : 1,82 Gio (5%)
Default                                  : Non
Audio #1
Nom commercial                           : Dolby Digital
Identifiant du codec                     : ac-3
Durée                                    : 2 h 1 min
Type de débit                            : Constant
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
ChannelLayout                            : L R C LFE Ls Rs
Echantillonnage                          : 48,0 kHz
Images par seconde                       : 31,250 Im/s (1536 SPF)
Profondeur des couleurs                  : 16 bits
Mode de compression                      : Avec perte
Taille du flux                           : 558 Mio (1%)
Langue                                   : Français
ServiceKind/String                       : Complete Main
Default                                  : Non
Audio #2
Durée                                    : 2 h 1 min
Débit                                    : 640 kb/s
Canaux                                   : 6 canaux
Langue                                   : Anglais
Default                                  : Non
Grencola
Post by Grencola »
mp4 also supports non-atmos 7.1 ALAC (Apple Lossless Audio Codec). if you want the keep the original ~7mbps audio (minus atmos) and get Dolby Vision at the same time it's pretty simple; True-HD / DTS-HD MA --> PCM 7.1 --> ALAC. obviously Apple TV 4k (and LG OLED's) support it just fine, not sure of all the specific models, though.
tr000
Post by tr000 »
OK, I figured out the problem totally. I have no idea how LG and Vizio TVs are doing Profile 7, but TVs are only supposed to support dvhe.04.07/dvhe.05.07 while UHD BD players can do dvhe.07.06/dvhe.07.07 which is what is mentioned in this thread. When I used dv-profile 5 instead of 7, it worked perfectly on my TCL Roku 4K TV and still retained 12 bit color info as it had two streams.
