SUPER SLIM DRIVE-USB 3.0 / Model Nr. ODP95-SU3
Ironsmurf64
Post by Ironsmurf64 » Fri Jul 19, 2019 8:17 am
The attachment MKV-Daten.PNG is no longer available
Hello
I bought a USB3.0 4K Blu-Ray drive and now wanted to read 4K movies on my PC, but I always get an error message.
Research in the forum has shown that the drive requires an update of the firmware.
1 question
in the mk-firmware-pack-20190319 is in the folder BU40N-N the same revision number (1.02) in it as in the drive?
2nd question
can you upgrade a USB 3.0 drive at all the firmware, if so how?
3.Frage
Which drives are Libredrive compatible?
so the Makemkv 4K UHD can read?
Sorry for the bad english, google translator helped me.
Kind regards
MakeMKV v1.14.4 win(x64-release) gestartet
Direkter Zugriffsmodus wird verwendet
DEBUG: Code 0 at NV{lMn5Qi[z1'%P21|:29396552
DEBUG: Code 4 at NV{lMn5Qi[z1'%P21|:29394275
AACS-VID kann nicht gelesen werden - höchstwahrscheinlich wird das AACS-Hostzertifikat durch Ihr Laufwerk aufgehoben
AACS Ausgabedatei als F:/Make_MKV_Daten/MKB20_v61_Star_Trek_Beyond_42A7.tgz gesichert
DEBUG: Code 0 at SYpXh>1]9aM.=fv`:29396092
DEBUG: Code 0 at SYpXh>1]9aM.=fv`:29395172
Das Öffnen der Disk schlug fehl
Re: SUPER SLIM DRIVE-USB 3.0 / Model Nr. ODP95-SU3
Post by MartyMcNuts » Sat Jul 20, 2019 1:16 am
Ironsmurf64 wrote: Fri Jul 19, 2019 8:17 am MKV-Daten.PNGHello
1 question
2nd question
3.Frage
Kind regards
For your BU40N, download the ASUS flasher + firmwares from the OP in thread https://www.makemkv.com/forum/viewtopic ... 16&t=18933. You should be able to flash DE BU40N 1.00 to your drive.
Some USB enclosures do allow drives to be flashed but you won't know until you try. If you get an error, let us know.
