Select options
dchamb
Select options
Is there a way currently to have MakeMKV select all tracks, including the sub tracks such as audio, subtitles, etc. I know you can go into each title and drop down to select everything for the title, but I am looking for a way to do this for all titles with one keystroke.
Re: Select options
Right-click on '... disc' (top-level, left-hand list) & 'Select all'. Works for individual titles, too.dchamb wrote: Fri Jul 19, 2019 6:32 pm Is there a way currently to have MakeMKV select all tracks, including the sub tracks such as audio, subtitles, etc. I know you can go into each title and drop down to select everything for the title, but I am looking for a way to do this for all titles with one keystroke.
dchamb
Re: Select options
I tried that and it doesn't work. I still have to go through and check the box of the tracks that are unchecked for each title.d00zah wrote: Fri Jul 19, 2019 7:16 pmRight-click on '... disc' (top-level, left-hand list) & 'Select all'. Works for individual titles, too.dchamb wrote: Fri Jul 19, 2019 6:32 pm Is there a way currently to have MakeMKV select all tracks, including the sub tracks such as audio, subtitles, etc. I know you can go into each title and drop down to select everything for the title, but I am looking for a way to do this for all titles with one keystroke.
Re: Select options
It's been so long since I set a custom selection rule that I had to go back & experiment...
Right-click on '... disc' allows (de)selection of listed 'titles'.
Right-click anywhere WITHIN any title allows (de)selection of contained tracks.
I'm unaware of any 'single keystroke' method.
IF you want MakeMKV to just select everything by default, set:
Preferred language: None
or play with custom selection rules ('Advanced' tab, exposed by checking 'expert mode' on 'General' tab):
ex: +sel:all
https://www.makemkv.com/forum/viewtopic ... 386#p17399
ex: +sel:all
dchamb
Re: Select options
I ended up changing Preferred Language to None and it selects all the tracks for all the titles. I just wasn't sure if this changes anything in the output MKV file such as default track flags.d00zah wrote: Fri Jul 19, 2019 11:25 pm It's been so long since I set a custom selection rule that I had to go back & experiment...
ex: +sel:all
When I right clicked on the "... disc" and did a Select All, but all it does is select the track level and nothing below it. You still would need to go to each track and "Select All". It would be nice if there were a "Select All Levels" at the disc level.
