I've been using this software for a little while now, and I've never had this issue, so I figured I'd post here. I tried ripping Independence Day on blu ray, and I'm getting random flashes of different patterns like the image attached. The glitched images flash for a minimal amount of time, and then the movie continues to play just fine... after a few more minutes, another flash... rinse and repeat.
I've tried playing the blu ray in a blu ray player, and I do not see the flashing. I've also tried ripping Independence Day Resurgence (they both were bundled together), and it plays just fine, so I can only assume it's the software with this particular blu ray. I just tried updating my blu ray drive's firmware, but that didn't seem to fix the issue. I have selected "Always created BD+ dumps," but I haven't been able to find any sort of log, unless this means just logging to the application's console as it's ripping.
If there's any sort of log file or output that I can upload to help y'all, that'd be great, and if anyone has anything they'd like me to try, I'd appreciate that as well.
Glitching after ripping blu ray
incutonez
- glitching.png (622.29 KiB) Viewed 12400 times
Grauhaar
Re: Glitching after ripping blu ray
Looks like an video decoding problem.
Can you tell us something about the viewing software/hardware and if media servers like plex etc. are involved.
Good Luck
incutonez
Absolutely. I was opening the mkv file, without converting from Handbrake, in both Windows Media Player and one of the other generic video apps on Windows 10 64bit. I did the same with the other mkv file for Independence Day Resurgence, and I didn't have the issue.
incutonez
Interesting, I think you're spot on here... I tried opening the file in VLC, and it didn't have the glitching. I'm going to try converting it with Handbrake, and getting it on Plex... I'll have a follow-up post with those results.
incutonez
Yeah, all seems well after converting and putting on Plex. Silly mistake on my part. Thanks for the help!
