Be My Valentine, Charlie Brown DVD - Weird behavior
danielrg
Post by danielrg »
This DVD rips okay, but the behavior is very odd.
For the main titles, the ripping starts, but appears to "hang" for about the first 10-12 minutes.
Weird things:
The read speed is lower than usual (about 3 MB/s, my usual is 8-10 MB/s) for the first 10-12 minutes
Output file status sits at 3.9KB - and file shows 0 in Explorer, doesn't change.
Status bar stays at zero
Disc drive light blinking like it is reading data
After about 10-12 minutes, the file would fill up almost instantly to about 300 MB, and then the rest of the rip would continue "normally", with the output file size updating, the speed would increase to more normal levels, and the progress bar would move regularly.
For a 2 GB title, it did this weird "hanging status, no file content" thing for ~12 minutes, getting a 300 MB file, then finished the rip with normal status, getting the remaining 1.7 GB in about 10 more minutes (22 min total)
It's kind of academic, since the files I ripped are good, but thought I'd share.
Here's the debug log:
Debug log started at Thu Jul 18 08:10:30 2019 , written by MakeMKV v1.14.4 win(x64-release)
001005:0000 MakeMKV v1.14.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\dgowans/MakeMKV_log.txt
No  SDF v05c: TSSTcorp_DVD+-RW_SU-208BB_D300_R8VQ6GCCB004GZ
SDF id v05c: TSSTcorp_DVD+-RW_SU-208BB_D300_R8VQ6GCCB004GZ
No auto SDF v05c: TSSTcorp_DVD+-RW_SU-208BB_D300_R8VQ6GCCB004GZ
DEBUG: Code 0 at }yJ2^mTS!\xYjfa7w:29395540
DEBUG: Code 0 at CG@,2:kgy4{A|JeZI:121261773
DEBUG: Code 0 at CG@,2:kgy4{A|JeZI:29393792
003019:0000 Cells 4-end were skipped due to cell commands (structure protection?)
003028:0000 Title #1 was added (2 cell(s), 0:50:33)
003025:0000 Title #2 has length of 12 seconds which is less than minimum title length of 15 seconds and was therefore skipped
003025:0000 Title #3 has length of 12 seconds which is less than minimum title length of 15 seconds and was therefore skipped
003028:0000 Title #4 was added (1 cell(s), 0:00:29)
003028:0000 Title #5 was added (1 cell(s), 0:01:17)
003028:0000 Title #6 was added (1 cell(s), 0:00:21)
003028:0000 Title #7 was added (1 cell(s), 0:25:13)
003028:0000 Title #8 was added (1 cell(s), 0:25:20)
003028:0000 Title #9 was added (1 cell(s), 0:15:02)
003028:0000 Title #10 was added (2 cell(s), 0:02:15)
003028:0000 Title #11 was added (1 cell(s), 0:01:02)
003028:0000 Title #12 was added (1 cell(s), 0:01:13)
003028:0000 Title #13 was added (1 cell(s), 0:00:16)
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
Title skip vts=3 pgcn=1 hash=150CD52D61F75193
003028:0000 Title #14/0/1 was added (1 cell(s), 0:24:18)
003028:0000 Title #15 was added (1 cell(s), 0:24:18)
003027:0000 Title 2 in VTS 3 is equal to title 1 and was skipped
003029:0000 Audio stream #2 is identical to stream #1 and was skipped
005014:0000 Saving 1 titles into directory C:/VideoMaster/Ripping/MakeMKV
AV sync issues in C:/VideoMaster/Ripping/MakeMKV/BE MY VALENTINE CHARLIE BROWN_t00.mkv
AV sync in 1 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8.994ms
AV sync in 2 at 0:00:00 (0ms) : 0 frame(s) dropped to reduce audio skew to +8.994ms
CCX001: Launching C:\Program Files (x86)\MakeMKV\mmccextr64.exe
CCX001: CCExtractor 0.85, Carlos Fernandez Sanz, Volker Quetschke.
CCX001: Teletext portions taken from Petr Kutalek's telxcc
CCX001: This is a reduced-functionality version optimised for DVD closed captions transcoding.
CCX001: --------------------------------------------------------------------------
CCX001: Reading from standard input
CCX001: Analyzing data in CCExtractor's binary format
CCX001: Sending captions to stdout.
DEBUG: Code 256 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 512 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 768 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 1024 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 1280 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 1536 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 1792 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 2048 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 2304 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 2560 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 2816 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 3072 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 3328 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 3584 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 3840 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 4096 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 4352 at *)sQF5!j965h>FtY#x;:213132652
<about 3800 more of these debug lines, just the "CODE #" part changing, otherwise the same>
DEBUG: Code 558848 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 559104 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 559360 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 559616 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 559872 at *)sQF5!j965h>FtY#x;:213132652
DEBUG: Code 560128 at *)sQF5!j965h>FtY#x;:213132652
AV sync in 1,2 at 0:00:00 (8.994ms) : encountered overlapping frame, audio skew is +8.994ms
AV sync in 1 at 0:25:14.837 (1.338ms) : encountered overlapping frame, audio skew is +10.333ms
AV sync in 2 at 0:25:14.837 (1.35ms) : encountered overlapping frame, audio skew is +10.344ms
004002:0000 Track #5 turned out to be empty and was removed from output file
005005:0080 1 titles saved
005036:0104 Copy complete. 1 titles saved.
Application exited at Thu Jul 18 08:33:43 2019
Re: Be My Valentine, Charlie Brown DVD - Weird behavior
That's the behavior of a drive trying REALLY HARD to read a marginal section of the disk.
danielrg
Post by danielrg »
Hmm, I just bought it. After your comment I saw that there are strange swirls on the disc, they look too perfect to be anything but something that happened mechanically, perhaps at the manufacturer. Well, I'm glad I successfully ripped it! Might get a replacement disc but if not, I have the content anyway.
Glad the drive tried so hard :-) The files play well.
Swirls put me in the mind of "rental disk, refinished to remove scratches". Used to see that a lot with Netflix rentals. Even had some disks I returned as unplayable come right back to me after polishing (they had other identifying marks that were unique).
