HDR10+
Unibrowser
HDR10+
Post by Unibrowser » Thu Jul 18, 2019 2:01 am
Warner brothers has confirmed that they will later this year start putting HDR10, HDR10+, and Dolby Visions HDR types on their disks(all 3 on every movie).
My question is, can MakeMKV rip the Dynamic HDR types? If so I'm pretty sure PLEX will be able to play them no issues. I know Samsung said it will support HDR10+. So I should be in the clear as long as MakeMKV can rip it.
This is the way
Re: HDR10+
Post by SamuriHL » Thu Jul 18, 2019 2:18 am
It's nowhere near that simple, but, to answer the immediate question, yes, MakeMKV will retain HDR and HDR10+ metadata. They are embedded in the video track. Dolby Vision....there's been an enormous amount of discussion around this topic so search this sub forum and you'll find it. I'm not sure Plex will pass through the HDR10+ metadata from an MKV container although to my knowledge no one's tried that yet. It...might work.
Unibrowser
Re: HDR10+
Post by Unibrowser » Thu Jul 18, 2019 2:27 am
That's good enough for me. I don't care about DV anyway because Samsung doesn't support it. The people on the PLEX forum assured me it will be no issue on that end. Thank you for the help
This is the way
