just wanted to report back that my Buffalo BRXL-PT6U2VB is a UHD-friendly device now:
1. Crossflashing worked like a charm with this MK firmware
2. Device shows up as LibreDrive compatible:
3. and CAN FINALLY READ UHD-blurays:
@mike admin
Just in case you might be still interested in Buffalo firmwares, they released a new FW update tool [brdrive_fwupdater_200.exe], featuring:
a. Buffalo_BU40N_FW_Updater_2.01.exe
b. Buffalo_BH16NS58_FW_Updater_2.01.exe
Is there a way to downgrade the firmware on a Buffalo BRUHD-PU3 from BU11 to BU10?
planet1
BRXL-PT6U2VB is UDH-friendly NOW
babypuncher
Re: Is there a way to downgrade the firmware on a Buffalo BRUHD-PU3 from BU11 to BU10?
Can anyone confirm if this works on a device that shows up as a BU11 rather than a BN11 in the modified ASUS flasher?
no idea just use my de bu10 i tested it on a buffalo drive that said bu11babypuncher wrote: Sat Jun 22, 2019 4:07 am Can anyone confirm if this works on a device that shows up as a BU11 rather than a BN11 in the modified ASUS flasher?
my de: https://www.makemkv.com/forum/viewtopic ... 873#p70284
martys asus flasher: https://www.makemkv.com/forum/viewtopic ... 16&t=18933
the drive can not be downgraded by the lg flasher in the case only the asus one works for that
@ Billycar11,
Have you come across a Buffalo BRUHD-PU3-BK with firmware BF11??
no i have not what interesting things have they come up with now?MartyMcNuts wrote: Wed Jul 17, 2019 6:34 am @ Billycar11,
I was thinking of getting one and they said it has BF11 on it.Billycar11 wrote: Wed Jul 17, 2019 7:19 amno i have not what interesting things have they come up with now?MartyMcNuts wrote: Wed Jul 17, 2019 6:34 am @ Billycar11,
i would think you are able to flash it if not mike could probably make up an MK for itMartyMcNuts wrote: Wed Jul 17, 2019 8:25 am
frankiepoon
My friend with bu11 can successfully downgraded to bu11 with the "DE_flash_HL-DT-ST_BD-RE_BU40N_BU10.bin" firmware. Thanks a lot!Billycar11 wrote: Sat Jun 22, 2019 5:00 amno idea just use my de bu10 i tested it on a buffalo drive that said bu11babypuncher wrote: Sat Jun 22, 2019 4:07 am Can anyone confirm if this works on a device that shows up as a BU11 rather than a BN11 in the modified ASUS flasher?
Info for drive [G:\] (DVDFab Passkey 9.3.5.4)
Vendor: BUFFALO, Product: Optical Drive
Revision: BU10, Vendor specific: O003703KZFI56D2038
yenchee1970
I found there is a new firmware at here. I extracted the latest BU12 for my BRUHD-PU3. How can I make it as MK firmware?
yenchee1970
Here is the BU12 for BRUHD-PU3 extracted from buffalo.jp. According to the site, it fixed Sony BD-QL media and DVD-RW write protect. How can I make it as MK firmware? Thanks.
Thanks for the link, MK firmware is now available.yenchee1970 wrote: Wed Sep 04, 2019 6:34 amHere is the BU12 for BRUHD-PU3 extracted from buffalo.jp. According to the site, it fixed Sony BD-QL media and DVD-RW write protect. How can I make it as MK firmware? Thanks.
Interesting. I've never ever seen BFxx (or a single reference to it).MartyMcNuts wrote: Wed Jul 17, 2019 6:34 amHave you come across a Buffalo BRUHD-PU3-BK with firmware BF11??
Yeah, it was an Amazon.com listing. One of the answers to a question was that it has firmware BF11. Don't know if that was actually correct or a typo? Anyway, I decided not to buy it.mike admin wrote: Wed Sep 11, 2019 9:10 pmInteresting. I've never ever seen BFxx (or a single reference to it).MartyMcNuts wrote: Wed Jul 17, 2019 6:34 amHave you come across a Buffalo BRUHD-PU3-BK with firmware BF11??
bioteq
Re: BRXL-PT6U2VB is UDH-friendly NOW
congrats on the upgraded drive, one question though - what updater did you use to get to bn11, I'm seeing only the 2.00 updater from Buffalo which you linked earlier, not sure if this contains what I need?planet1 wrote: Wed Jun 19, 2019 10:25 pm just wanted to report back that my Buffalo BRXL-PT6U2VB is a UHD-friendly device now
Do I even need to update or do I just cross-flash to 1.03 from Mike?
Thanks for all the info!
Only 10 months late but is this what you are after?jonghotti wrote: Fri Apr 26, 2019 3:09 am So the buffalo drives with the BU40N in it can simply be flashed with BU40N 1.00 and they'll come back saying Buffalo xxxxx BU10.
I'm wondering about the Buffalo BRXL-16U3 big external drive that contains a BH16NS58 in it with revision 1.01. Is there a 1.00 around for the BH16NS58? Still need to figure out how to remove this case unless you guys are going to tell me we can flash over USB now![]()
