This is how I solved this issue:
I use this naming scheme in MakeMKV:
I change the name of the disc to "disc1" or "dvd1" etc. This will produce files as follows:
/Showname (2019)/disc1_t01.mkv
/Showname (2019)/disc1_t02.mkv
/Showname (2019)/disc2_t01.mkv
/Showname (2019)/disc1_t03.mkv
By that I select only episodes and no bonus content. If I like to rip bonus content I name it directly inside of MakeMKV or start a second turn and use a subfolder as target.
After that I copy & paste all files into Filebot:
- 2019-12-27 12_11_27.png (120.9 KiB) Viewed 16284 times
then I search through the Episodes-tab for the TV show and copy & paste the results to the Rename-tab. By that Filebot does not use any automatism to assign the files to the correct episode names. Instead its a "manual" assignment based on the alphabetical order of the filenames and the episode order returned by the database.
Further explanation:
https://www.filebot.net/forums/viewtopi ... 594#p47594
This works only if the episodes have the same order and amount as returned by the database. If the discs contain random episodes like the Disney Animated Short Movies then this won't work. For those TV shows you still need to manually name them before using Filebots classic automatism.
Of course Filebot costs money, but its a huge time saver.
