Tried with DE_flash_HL-DT-ST_BD-RE_BU40N_BU10.bin firmware and just go a error: Updating Failure #4.
Firmware downgrade using official (patched) flasher, the "Ultra hax0r guide"
Re: Firmware downgrade using official (patched) flasher, the "Ultra hax0r guide"
How can i downgrade Buffalo BRUHD-PU3 with BU12 to BU10?
Use mk 1.03 for bu40n in that drive it is a BU40N it's probably just a rebaged 1.03Amasakre wrote: Tue Jul 16, 2019 1:46 pm How can i downgrade Buffalo BRUHD-PU3 with BU12 to BU10?
icedragonslair
Amazing, worked like a charm on my WH16NS60Billycar11 wrote: Wed Feb 06, 2019 12:37 am Downgrade Enabled Firmware V.2
https://drive.google.com/file/d/102V7DU ... sp=sharing
MD5: D9166F375D82D808411549BF615EE70E
SHA-256: 64084863829C3C8EFABF6ED786DAC426AC70C23AE02D7525C36C369841C869B0
Thanks so much man,
Ice
hi everyone
i buy a BRUHD-PU3 , FM version is bu12
first i use this post BH14NS40_N1.00-A4_patched.exe and it show 'ATAPI device can not be found F/W model is BD-RE BH14NS40.'
i use other laptop but it show the same message.
so i try the other way , use ASUS_ODD_FW_Changer_(Modified) and show update fail
please help, thank you
JohnnyJones
First, this board is full of amazing information!
Now to my issue: Have tried to follow BillyCar's instructions for flashing the WH16NS60 1.02 to the supplied 1.00.bin but to no avail.
Getting the following: Write DRAM NG 05/26/03
Any else run into this?
Use the ASUS flasher and flash BU40N_1.03_MK. This should work. Then you can flash other firmware if you like.hdxXD wrote: Mon Jul 29, 2019 7:17 am hi everyone
I haven't seen a NS60 with 1.02 as yet but use the ASUS flasher and try flashing ASUS 3.10-MK. If this works, you can then flash NS60 1.00 firmware.JohnnyJones wrote: Sun Aug 04, 2019 8:47 pm First, this board is full of amazing information!
Or use the new NS55 MK 1.04 first, then NS60 1.00 or MK 1.01. Then you "keep it in the family". LOL
Just wanted to say thank you to the developers for offering the firmware downgrade to get my LG drive UHD 'friendly'. I am always so impressed with the folks on these sites for 1) being way smarter than I to create stuff like this, and 2) for being so generous in sharing their labor. You are all awesome !
SmoothRunnings
I am stuck with this.
I have a brand new LG WH16NS40 with FW 1.04 installed. When I tried to downgrade the FW to 1.02 using the unlocker app it tells me Write DRAM NG 05/26/03. I checked the SVC on the drive as well and it shows NS50.
So can someone give me hand?
I tried my John Wick 2 4K UHD disc tonight and the drive doesn't even see the disc.
Thanks,
Thanks,
You must flash either BH16NS55_1.04_MK or ASUS_BW-16D1HT_3.10_MK first, then you can flash 1.02 if you want.SmoothRunnings wrote: Sat Sep 07, 2019 1:43 am I am stuck with this.
Thanks,
Just wanted to say that I bricked a year-old WH16NS40. I bought a new one & had Billycar11 remotely change the firmware. Took all of 7 minutes. Highly recommended.
Special thanks to Billycar11 for the video and links on the youtube video.
I have the WH16NS40 svc code NS50. I've downgraded from 1.03 to 1.02. Thanks for the great software and forum!
Quick Question: Does LibreDrive make it unnecessary to downgrade my particular drive? If so, is it now recommended that I upgrade the Firmware to latest version?
LibreDrive does not necessarily equal UHD compatible.eddified wrote: Mon Sep 23, 2019 12:34 am Special thanks to Billycar11 for the video and links on the youtube video.
If your drive is working well and you are happy, leave it as is. Otherwise, you could flash the newer version and if it breaks UHD compatibility, just downgrade it again. Easy Peasy!!
I have the same problem as SmoothRunnings. I have a brand new WH16NS40 (DOM: August 19) with 1.04 firmware. Before I do anything I wanted to confirm I need to:
1. Cross flash either BH16NS55_1.04_MK or ASUS_BW-16D1HT_3.10_MK using the ASUS flasher
2. Flash the DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin using the old flasher
3. Flash the HL-DT-ST-BD-RE_WH16NS40-NS50-1.03-NM00600-211711211653.bin from the mk-firmware file
Is this correct or will I end up bricking my new drive? I also can't use dosflash because I don't have access to a PC with an IDE compatible bios so if I mess something up its messed up for good.
