LG BH16NS55 Firmware 1.04 (and possibly other new drives)
killkong1211
Re: LG BH16NS55 Firmware 1.04 (and possibly other new drives)
Post by killkong1211 »
Fair enough, wasn't aware that didn't apply so was just outlining all my troubleshooting.
Any advice on how to proceed from here?
killkong1211 wrote: Mon Jul 15, 2019 11:04 am Hey all,
New here.
Just bought an LG BH16NS55 with firmware 1.04
Was getting nowhere on my win10 machine (probably because it only has AHCI)
I've hooked it up to a Win7 machine with AHCI disabled in bios, attempted to flash to asus 3.10 bios with both the asus odd and lg crossflash utilities and still no go.
asus odd gives me Update Failure #4 errors and the lg crossflash gives me errors.
I'm sure there's something simple I'm overlooking, anyone have any insight?
How is your drive connected to PC? I think Failure #4 is usually when an adapter or something is not passing the required commands through to the drive.
Post by SamuriHL »
Except if they're playing with AHCI that tells me they're on SATA, no?
killkong1211
No adapter straight to the board (on both pc's)
David2piter
Post by David2piter »
thats great !
killkong1211
Also I'll just note those are the errors appearing on the Win7 machine, win10 gives me different errors (see attached)
Again connected on sata straight to the board
killkong1211 wrote: Tue Jul 16, 2019 7:58 am Also I'll just note those are the errors appearing on the Win7 machine, win10 gives me different errors (see attached)
A program on your pc is probably taking exclusive control of your optical drives not allowing them to be flashed I have seen this a few times when remote flashing for people. Close all programs that have anything to do with optical drives
killkong1211
Billycar11 wrote: Tue Jul 16, 2019 6:16 pm A program on your pc is probably taking exclusive control of your optical drives not allowing them to be flashed I have seen this a few times when remote flashing for people. Close all programs that have anything to do with optical drives
Didn't have any apps running that should be accessing the drive to my knowledge.
Any specific apps you're aware of that might be doing things in the background? (I.e. antivirus, chrome, etc)
Post by SamuriHL »
I can also be screwed up drivers and filters.
killkong1211
SamuriHL wrote: Tue Jul 16, 2019 9:09 pm I can also be screwed up drivers and filters.
Drivers I can redownload, but what do you mean by filters?
Post by SamuriHL »
https://www.techsupportall.com/fixed-so ... er-filter/
It doesn't just apply to optical drives that can't be found. Messed up filters can cause other issues, as well.
killkong1211
SamuriHL wrote: Tue Jul 16, 2019 10:48 pm https://www.techsupportall.com/fixed-so ... er-filter/
I'll give that a go this arvo after work, will post results
killkong1211
No luck on filters, didn't have an upper or lower filter in that registry key.
On the win10 or win7.
No luck on a program taking control, I shut off virtually every process on the windows 10 machine so it was just task manager and the lg crossflasher running.
killkong1211 wrote: Wed Jul 17, 2019 7:37 am
try making a bootable pe windows on a flashdrive https://www.aomeitech.com/pe-builder.html i have flashed 100+ drive in that it should work
the asus flasher wont work on that one no .net but that eliminates the software variables completely.
then you just try asus 3.10mk with the lg flasher and see if it works if not your probably just better buying a preflashed one
because then your sata controller or something is not passing the commands
killkong1211
Billycar11 wrote: Wed Jul 17, 2019 7:54 am
I'm in PE now but the lg flasher won't launch, it should just launch if I try to run it yeah? No extra steps needed?
Edit: tried to launch from cmd and got the attached
