DVD menu
jacthemanus
DVD menu
#1 Post by jacthemanus » Wed Sep 15, 2010 5:04 pm
When I make a mkv file from a dvd, how do I include the menu? I made the mkv file from a DVD but when I play it, it does not show the root menu where I can do the scene selection. Thanks
nick1977
Re: DVD menu
#2 Post by nick1977 » Wed Sep 15, 2010 8:35 pm
As far as I'm aware, mkv's don't support DVD menus. At least not yet...
You should find that the chapter points are there though, so to access scenes, you need to start playing and then skip to the relevant chapter point.
Nick
martin68
Re: DVD menu
#3 Post by martin68 » Sun Sep 19, 2010 11:22 am
Look at http://www.matroska.org/technical/whatis/index.html what mkv is and wich features there are available.
Menus/chapters are available.
If you look on a makemkv generated mkv-file with Mediainfo (free download available on matroska.org), you'll see chapters there. Maybe your media player does not support this. You'll find there also some mediaplayers - f.e. "Media Player Classic", which support chapters.
F.e. DVD "Einer flog ?ber das Kuckucksnest"
Vollst?ndiger Name : C:\Video\Einer flog ?ber das Kuckucksnest\title00.mkv
Format : Matroska
Dateigr??e : 3,61 GiB
Dauer : 2h 8min
Gesamte Bitrate : 4 024 Kbps
Kodierungs-Datum : UTC 2010-09-19 09:42:41
Kodierendes Programm : MakeMKV v1.6.0 win(x86-release)
verwendete Encoder-Bibliothek : libmakemkv v1.6.0 (0.7.7/0.8.1) win(x86-release)
Video
Format : MPEG Video
Format-Version : Version 2
Format-Profil : Main@Main
Format-Einstellungen f?r BVOP : Nein
Format-Einstellungen f?r Matrix : ?blich
Codec-ID : V_MPEG2
Codec-ID/Info : MPEG 1 or 2 Video
Dauer : 2h 8min
Bitraten-Modus : variabel
Bitrate : 3 751 Kbps
nominale Bitrate : 7 500 Kbps
Breite : 720 Pixel
H?he : 576 Pixel
Bildseitenverh?ltnis : 16:9
Bildwiederholungsrate : 25,000 FPS
Standard : PAL
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scantyp : Interlaced
Scanreihenfolge : oberes Feld zuerst
Bits/(Pixel*Frame) : 0.362
Stream-Gr??e : 3,37 GiB (93%)
Sprache : Englisch
Audio
Format : AC-3
Format/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Codec-ID : A_AC3
Dauer : 2h 8min
Bitraten-Modus : konstant
Bitrate : 192 Kbps
Kan?le : 1 Kanal
Kanal-Positionen : Front: C
Samplingrate : 48,0 KHz
BitDepth/String : 16 bits
Video Verz?gerung : -80ms
Stream-Gr??e : 176 MiB (5%)
Titel : 1/0
Sprache : Deutsch
Men?
00:00:00.000 : en:Chapter 01
00:04:12.920 : en:Chapter 02
00:08:22.600 : en:Chapter 03
00:13:34.120 : en:Chapter 04
00:20:29.720 : en:Chapter 05
00:24:15.120 : en:Chapter 06
00:26:31.200 : en:Chapter 07
00:30:20.680 : en:Chapter 08
00:33:02.320 : en:Chapter 09
00:37:53.240 : en:Chapter 10
00:45:37.120 : en:Chapter 11
00:47:03.880 : en:Chapter 12
00:49:33.800 : en:Chapter 13
00:52:58.040 : en:Chapter 14
00:59:47.480 : en:Chapter 15
01:03:01.120 : en:Chapter 16
01:04:26.240 : en:Chapter 17
01:06:52.520 : en:Chapter 18
01:08:06.920 : en:Chapter 19
01:16:19.760 : en:Chapter 20
01:23:31.240 : en:Chapter 21
01:26:08.560 : en:Chapter 22
01:33:09.640 : en:Chapter 23
01:34:04.400 : en:Chapter 24
01:37:29.480 : en:Chapter 25
01:40:51.880 : en:Chapter 26
01:46:21.800 : en:Chapter 27
01:48:52.000 : en:Chapter 28
01:54:24.080 : en:Chapter 29
01:57:25.240 : en:Chapter 30
01:59:21.920 : en:Chapter 31
02:04:01.600 : en:Chapter 32
02:06:18.080 : en:Chapter 33
Martin
