Braveheart 4K
feelmyhatred
Braveheart 4K
#1 Post by feelmyhatred » Thu Jul 11, 2019 1:41 pm
my 4K Blu Ray Drive is unable to rip this UHD Movie. I downloaded the newest hashed key list (Updated March 2019) I did sent the dump file to the given Email two weeks ago, but nothing happend yet. Any Tips?
st4evr
Re: Braveheart 4K
#2 Post by st4evr » Thu Jul 11, 2019 4:53 pm
There is plenty of advise in this thread:
https://www.makemkv.com/forum/viewtopic ... 12&t=19567
Re: Braveheart 4K
#3 Post by MartyMcNuts » Thu Jul 11, 2019 11:41 pm
feelmyhatred wrote: Thu Jul 11, 2019 1:41 pm Hello,
The public hashed key file is not updated anymore. You must turn on "Contact server for updates" option in the preferences. Then once you insert a disc and start a back-up, the latest keys inside the private_data.tar file will be automatically updated and ripping should commence.
sharf
Re: Braveheart 4K
#4 Post by sharf » Thu Jul 25, 2019 10:22 pm
I just purchased the 4k HDR UHD Version from best buy in the US, and makemkv/windows in general don't seem to be able to recognize the disk. Makemkv starts trying to read and shows the spinning animation, but then stops and just shows "no disc".
I had the same issue with Planet Earth II recently, so I bought the recommended asus drive (forget the model number off hand, but it was from the thread) and flashed the firmware etc. I was able to rip Planet Earth II no problem, and other 4k HDR UHD discs, but this one doesn't seem to be working. I have confirmed the disc is good and plays in my xbox one x.
Any advice?
