BitJam2
#1
Post
by BitJam2 » Tue Sep 14, 2010 6:53 pm
I have a dvd drive at /dev/sr0 and a bluray/dvd drive at dev/sr1. I figured that if I'm always streaming blurays then I would always use "disc:1" with makemkvcon. But that only works when there is a disc in the /dev/sr0 device. If there is no disc in /dev/sr0 but there is a bluray disc in /dev/sr1 and I try to "makemkvcon stream disc:1" then I get a segfault. Here is the debug log:
Debug log started at Tue Sep 14 18:36:20 2010 , written by MakeMKV v1.5.8 linux(x64-release)
001005:0000 MakeMKV v1.5.8 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /home/jbowlin/MakeMKV_log.txt
001003:0020 DEBUG: Code 0 at ={DN#c^S5134#z2N;qsM:213130122
So if there is no disc in /dev/sr0 then I have to use "disc:0" to read the disc from /dev/sr1. But if there is a disc in /dev/sr0 then I have to use "disc:1" to read the disc from /dev/sr1.
I think it would be easier for GNU/Linux users if there was a fixed relationship between makemkvcon's disc:$N and the /dev/sr$N devices. I've seen in another thread that it is unlikely this will happen anytime soon. It's certainly more of an annoyance than a show-stopper but it is an annoyance.
#2
Post
by mike admin » Wed Sep 15, 2010 7:11 am
Please post /proc/sys/dev/cdrom/info for both cases.
BitJam2
#3
Post
by BitJam2 » Wed Sep 15, 2010 8:00 pm
The contents of /proc/sys/dev/cdrom/info do not change when I insert discs into the drives. So in all cases it gives:
With only Bluray disc in sr1, need to use "disc:0"
CD-ROM information, Id: cdrom.c 3.20 2003/12/17
drive name: sr1 sr0
drive speed: 102 12
drive # of slots: 1 1
Can close tray: 1 1
Can open tray: 1 1
Can lock tray: 1 1
Can change speed: 1 1
Can select disk: 0 0
Can read multisession: 1 1
Can read MCN: 1 1
Reports media changed: 1 1
Can play audio: 1 1
Can write CD-R: 0 1
Can write CD-RW: 0 1
Can read DVD: 1 1
Can write DVD-R: 0 1
Can write DVD-RAM: 0 1
Can read MRW: 1 1
Can write MRW: 1 1
Can write RAM: 1 1
I tried to replicate the problem this morning to be sure the contents of /proc/sys/dev/cdrom/info corresponded to the failure modes I reported. Of course, the failure modes changed. Today disc:0 corresponds to sr1 and disc:1 corresponds to sr0. This does not change when I insert or remove media. I get a segfault when I try to read from an empty drive and I also got a couple of "random" segfaults when trying to read from a drive that contained a disc.
I will try to replicate the original problem I reported after I reboot and if I can replicate it I will post the contents of /proc/sys/dev/cdrom/info.
BitJam2
#4
Post
by BitJam2 » Thu Sep 16, 2010 4:37 am
After rebooting the "drive speed" line /proc/sys/dev/cdrom/info has changed. All the other lines are the same as before:
drive name: sr1 sr0
drive speed: 32 94
Can close tray: 1 1
Can open tray: 1 1
Can lock tray: 1 1
Can read MCN: 1 1
Can play audio: 1 1
Can write CD-R: 0 1
Can read DVD: 1 1
Can read MRW: 1 1
Can write MRW: 1 1
Can write RAM: 1 1
And now disc:0 corresponds to sr0 and disc:1 corresponds to sr1. The correspondence does not seem to depend on which drives has discs inserted. I still get random segfaults.
