The Spy Who Loved Me will not rip
rjlynn
#1 Post by rjlynn » Sun Sep 12, 2010 5:54 pm
MakeMKV stalls processing titles:
MakeMKV v1.5.8 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Rob/MakeMKV_log.txt
Title #0 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2/1 was added (1 cell(s), 0:05:00)
Title #2/2 was added (3 cell(s), 0:09:00)
Title #6 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 with special attributes was skipped
Cells 36-end were skipped due to cell commands (structure protection?)
If I leave it going, I get plenty of junk in the MakeMKV log:
001003:0020 DEBUG: Code 2 at 8kJmBCi*F;4g`Yps:213135251
etc...
Re: The Spy Who Loved Me will not rip
#2 Post by mike admin » Tue Sep 14, 2010 7:32 am
Please post the full log.
rjlynn
#3 Post by rjlynn » Tue Sep 14, 2010 6:46 pm
Debug log started at Tue Sep 14 05:27:53 2010 , written by MakeMKV v1.5.8 win(x64-release)
Using 490752KB for read cache.
001005:0000 MakeMKV v1.5.8 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Rob/MakeMKV_log.txt
003025:0000 Title #0 has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #2/1 was added (1 cell(s), 0:05:00)
003028:0000 Title #2/2 was added (3 cell(s), 0:09:00)
003025:0000 Title #6 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003013:0000 Title #7 with special attributes was skipped
003019:0000 Cells 36-end were skipped due to cell commands (structure protection?)
001003:0020 DEBUG: Code 0 at cl4h5|!16|*e)]dJ?:121263153
001003:0020 DEBUG: Code 0 at cl4h5|!16|*e)]dJ?:29395172
003028:0000 Title #10 was added (35 cell(s), 2:05:18)
003025:0000 Title #12 has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14 has length of 102 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005011:0000 Operation sucessfully completed
005014:0000 Saving 1 titles into directory C:/Video/The_Spy_Who_Loved_Me
002003:0000 Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occured while reading '/VIDEO_TS/VTS_10_1.VOB' at offset '282888192'
001003:0020 DEBUG: Code 0 at }&i)/,Bl1a7DLNqM:213136769
001003:0020 DEBUG: Code 100941314 at }1=ipBp?g(KEt3a_1@:121263636
001003:0020 DEBUG: Code 100941314 at }1=ipBp?g(KEt3a_1@:213130007
001003:0020 DEBUG: Code 0 at F,8'XhP~=JiSm$lNbOCO:213130628
001003:0020 DEBUG: Code 0 at rqRKLouR{ SWzIg@'"_:121261704
001003:0020 DEBUG: Code 0 at F,8'XhP~=JiSm$lNbOCO:213130513
001003:0020 DEBUG: Code 138129 at F,8'XhP~=JiSm$lNbOCO:213129639
005003:0000 Failed to save title 2 to file C:/Video/The_Spy_Who_Loved_Me/title02.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Tue Sep 14 18:37:30 2010
The disk is perfectly clean and plays fine in the same computer. Fails both on direct hardware access and not.
#4 Post by mike admin » Wed Sep 15, 2010 7:02 am
This looks like a damaged disc.
twa000
#5 Post by twa000 » Thu Sep 16, 2010 6:28 am
The European version ripped OK for me
