Alldu
#466 Post by Alldu » Wed Jul 03, 2019 10:19 am
Grencola wrote: Tue Jul 02, 2019 10:55 pm
Alldu wrote: Tue Jul 02, 2019 10:30 pm
Grencola wrote: Tue Jun 25, 2019 10:54 pm
no prob man. should work with everything SubtitleEdit supports; pgs, sub, ocr, srt, etc..
Hi Grencola, so I tried your subtitles tool on Spider-Man Homecoming and unfrotunately it gives me an error:
This subtitle conversion is not supported.
This file does not contain a Dolby Vision video track. Try another file!
THis is an .m2ts file, and then I try the usual dv-mp4-maker on it, it makes a perfect mp4 with Dolby Vision. Any idea what am I doing wrong? Many thanks!
weird, SubtitleEdit seems to struggle with zib subs, I haven't seen them before either. just extract this: https://subdl.com/subtitle_dl.php?p=L3N ... 8xNzg0NTMx into your movie folder and rename it to match your mp4.
https://subdl.com usually has it if you can't make one.
Hmm, sorry, don't want to be "that guy", but it still isn't working... I uploaded the subs you've shared to the folder where m2ts file was and renamed it, still same error...
Grencola
#467 Post by Grencola » Wed Jul 03, 2019 1:22 pm
Alldu wrote: Wed Jul 03, 2019 10:19 am Hmm, sorry, don't want to be "that guy", but it still isn't working... I uploaded the subs you've shared to the folder where m2ts file was and renamed it, still same error...
put it in the same folder as your dv mp4. make the .srt and the .mp4 the exact same filename. play your mp4 and you will get subs. might have to enable them during playback depending on device.
Grencola
#468 Post by Grencola » Wed Jul 03, 2019 2:32 pm
Redhawk2000 wrote: Sun Jun 30, 2019 12:08 am Anyone have any idea if the newer lg c9 with HDMI 2.1 and eARC would be able to play full DV disc rips via USB or Ethernet and then output (via eARC) lossless audio to a receiver?
I ask because I just ordered a c8 on sale but would cancel it if the above was a maybe.
You'll only get HDR10 if you try this. You either need an Oppo uhd-bd player (or its clone), or a converted MP4 to get Dolby Vision, the latter only has lossy audio. The Matroska devs are working on an MKV update to support Dolby Vision, but there's no ETA as of yet.
Donpoku
#469 Post by Donpoku » Wed Jul 03, 2019 3:47 pm
Hi peeps, anyone know if this will work on 4k fire TV stick Dolby vision via NAS on lg c6 TV? Thank you.
Redhawk2000
#470 Post by Redhawk2000 » Thu Jul 04, 2019 12:40 am
Grencola wrote: Wed Jul 03, 2019 2:32 pm
Thanks. Especially the info in the last sentence. Glad to hear.
cyperous
#471 Post by cyperous » Fri Jul 05, 2019 12:37 am
cyperous wrote: Tue Jun 18, 2019 2:16 am
sm0ke83 wrote: Sat May 25, 2019 7:04 pm
cyperous wrote: Fri May 17, 2019 9:05 pm Found some more interesting info that might help.
I did find out that seeking is working but it is very cpu intensive and on my 6 core 12 thread machine, it maxes the cpus to 100% and takes over a minute for the seek to happen. The TV is probably giving up after a short period and just starts over from the beginning.
I tried doing some research around 10bit 265 and mp4's and it turns out that mp4muxer does not write the file correctly that would build a resulted file that is seeable under a normal conditions.
For clarification here are the commands I ran to build comparison files, NOTE: these are all without dv files.
mp4muxer -i video.265 -i audio.ac3 -o temp_mp4muxer.mp4
mp4box -add video.265 -add audio.ac3 -new temp_mp4box.mp4
ffmpeg -i video.265 -i audio.ac3 -c copy -map 0:0 -map 1:0 temp_ffmpeg.mp4
ffmpeg and mp4box produce a seekable file whereas mp4muxer does not.
I would also like to note that all three of these command produce different byte codes.
Overlooked this... need to look into this too also I think...
Yeah, I'm glad someone else noticed.
For now I'm just caching the DV Layer so I can potentially fix the seeking later without having to re-rip all my DV titles.
I think I have solved the mystery of re-encoded DV rips not being able to seek effiently.
I was playing around with the raw streams and noticed that seeking was fine but not after re-encoding the hdr10 portion of the stream.
After playing around with several options, I found that adding the following option to handbrake solved my seeking issues.
uhd-bd=1
This adds uhd compatibility. There is one catch this option forces crf. Which is fine for me cause I was already using it to re-encode. I compared my hdr10 file before and after using this option and it only increased the file size by 1G.
Hopefully this helps others who are re-encoding.
Alldu
#472 Post by Alldu » Fri Jul 05, 2019 8:47 am
Grencola wrote: Wed Jul 03, 2019 1:22 pm
Duh, finally I understand what you meant :D Thanks again, you rule! All works like a charm!
Donpoku
#473 Post by Donpoku » Fri Jul 05, 2019 9:01 am
powdeau wrote: Thu Jun 20, 2019 2:39 pm
murrayit wrote: Tue Jun 18, 2019 4:43 am
powdeau wrote: Fri May 17, 2019 1:21 am
I have LG C7 and I also have these artifacts in some movies. It is not because of DV or a HDD, but because of the player in TV. It cause artifacts also on the remuxes or on the m2ts files from ISO. It's too bad that LG didn't fix it on new model (also someone should try it on C7). I fixed this by buying Sony X700 where it works fine.
I just have an issue there with DV. Sometimes, when there is a change of the shot in the movie, the screen flashes for a 1 frame. If someone know how to fix this, it would be awesome. I have this problem just with DV.
I also experience these artifacts on OLED B7. For example in Captain America Civil War or Us or many other titles. It has nothing to do with mp4 DV discs though...
Any solutions for these? Or any suggested player which has the same picture quality as well as DV playback (I can't afford Oppo...)
Yes, the Sony X700.
Hello, lg c6 owner here, will Sony X700 get rid of all the green tint movies and does it play 3d ISO? Thanks.
daddy
#474 Post by daddy » Sat Jul 06, 2019 9:18 am
From what i know, the C9 is unable to play .iso files.
The C9 can play m2ts files from a BDMV/STREAM folder, but they will play only in hdr10.
So, the only way to get DV from a file is to make a mp4 file with the mp4muxer from DolbyLaboratories.
You can't have DV and lossless audio.
The mp4 file supports only Dolby Digital (AC-3), Dolby Digital Plus (E-AC-3), and Dolby AC-4.
tr000
#475 Post by tr000 » Fri Jul 19, 2019 11:33 pm
I have a TCL Dolby Vision TV. Here are some files that play.
Complete name                            : F:\Demos\Dolby OnOff.ts
File size                                : 678 MiB
Duration                                 : 2 min 17 s
Overall bit rate mode                    : Constant
Overall bit rate                         : 41.5 Mb/s
Video
Menu ID                                  : 2 (0x2)
Format profile                           : Main 10@L5.1@Main
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Bit rate                                 : 38.9 Mb/s
Chroma subsampling                       : 4:2:0
Bits/(Pixel*Frame)                       : 0.196
Stream size                              : 636 MiB (94%)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Format/Info                              : Enhanced AC-3 with Joint Object Coding
Commercial name                          : Dolby Digital Plus with Dolby Atmos
Codec ID                                 : 135
Duration                                 : 2 min 16 s
Bit rate                                 : 504 kb/s
Stream size                              : 8.20 MiB (1%)
Complexity index                         : 16
Number of dynamic objects                : 15
Complete name                            : F:\Demos\food.60.dm1_U30000_mz.ts
File size                                : 287 MiB
Duration                                 : 1 min 16 s
Overall bit rate                         : 31.6 Mb/s
Video
Menu ID                                  : 2 (0x2)
Bit rate                                 : 29.4 Mb/s
Frame rate                               : 60.000 FPS
Bits/(Pixel*Frame)                       : 0.059
Stream size                              : 266 MiB (93%)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 135
Duration                                 : 1 min 15 s
Stream size                              : 5.77 MiB (2%)
General
Complete name                            : F:\Demos\NASA (Dolby Vision).mp4
Format profile                           : Base Media / Version 2
Codec ID                                 : mp42 (mp42/dby1/isom)
File size                                : 510 MiB
Duration                                 : 2 min 23 s
Overall bit rate                         : 29.9 Mb/s
Encoded date                             : UTC 2017-04-13 22:51:30
Tagged date                              : UTC 2017-04-13 22:51:30
Video
HDR format                               : Dolby Vision, Version 1.0, dvhe.05.09, BL+RPU
Bit rate                                 : 29.3 Mb/s
Frame rate                               : 59.940 (60000/1001) FPS
Stream size                              : 499 MiB (98%)
Audio
Format                                   : E-AC-3 JOC
Codec ID                                 : ec-3
Duration                                 : 2 min 22 s
Bit depth                                : 16 bits
Stream size                              : 10.9 MiB (2%)
Complexity index                         : 14
Number of dynamic objects                : 13
This sample video someone on Reddit uploaded also works, though with no audio.
General
Complete name                            : F:\Batman vs. Superman_cutted.m2ts
Format                                   : BDAV
Format/Info                              : Blu-ray Video
File size                                : 449 MiB
Duration                                 : 2 min 20 s
Overall bit rate                         : 26.8 Mb/s
Video
Menu ID                                  : 2 (0x2)
Format profile                           : Main 10@L5@Main
Duration                                 : 2 min 21 s
Bit rate                                 : 25.1 Mb/s
Bits/(Pixel*Frame)                       : 0.126
Stream size                              : 422 MiB (94%)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 6
Delay relative to video                  : -486 ms
Stream size                              : 10.7 MiB (2%)
Language                                 : French
Complexity index                         : 12
FIles made using the method in this thread do not work. They start with a green screen then I can see the video, but with horribly distorted colors.
Video #1
HDR format                               : SMPTE ST 2086, HDR10 compatible
Duration                                 : 1 min 0 s
Bit rate                                 : 44.5 Mb/s
Bits/(Pixel*Frame)                       : 0.224
Stream size                              : 322 MiB (89%)
Title                                    : Transformers.2007.2160p.BluRay.REMUX.HEVC.DTS-HD.MA.TrueHD.7.1.Atmos-FGT
Video #2
Bit rate                                 : 4 903 kb/s
Width                                    : 1 920 pixels
Height                                   : 1 080 pixels
Bits/(Pixel*Frame)                       : 0.099
Stream size                              : 35.4 MiB (10%)
Audio
Codec ID                                 : A_AC3
Bit depth                                : 16 bits
Stream size                              : 4.63 MiB (1%)
Any ideas on how to get remuxed MKVs with two video tracks into one DV track that plays on my TV?
#476 Post by MartyMcNuts » Sat Jul 20, 2019 1:07 am
tr000 wrote: Fri Jul 19, 2019 11:33 pm I have a TCL Dolby Vision TV. Here are some files that play.
File size                                : 678 MiB
Video
Menu ID                                  : 2 (0x2)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 135
Bit rate                                 : 504 kb/s
File size                                : 287 MiB
Video
Menu ID                                  : 2 (0x2)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 135
General
File size                                : 510 MiB
Video
Audio
Format                                   : E-AC-3 JOC
Codec ID                                 : ec-3
Bit depth                                : 16 bits
General
Format                                   : BDAV
File size                                : 449 MiB
Video
Menu ID                                  : 2 (0x2)
Audio
Menu ID                                  : 2 (0x2)
Format                                   : E-AC-3 JOC
Codec ID                                 : 6
Language                                 : French
Video #1
Video #2
Audio
Codec ID                                 : A_AC3
Bit depth                                : 16 bits
You could try CloneBD.
tr000
#477 Post by tr000 » Sat Jul 20, 2019 4:18 am
MartyMcNuts wrote: Sat Jul 20, 2019 1:07 am You could try CloneBD.
Does that work with .mkv files? I was under the impression that it required a full Blu Ray with BDMV folder structure intact and then converts it to a DV MP4, like DVDFab.
#478 Post by MartyMcNuts » Sat Jul 20, 2019 6:40 am
tr000 wrote: Sat Jul 20, 2019 4:18 am
You need either disc/iso/folder to use CloneBD
tr000
#479 Post by tr000 » Sat Jul 20, 2019 7:11 am
MartyMcNuts wrote: Sat Jul 20, 2019 6:40 am
That's what I thought. Guess I should get some full Blu-rays then.
#480 Post by MartyMcNuts » Sat Jul 20, 2019 7:50 am
tr000 wrote: Sat Jul 20, 2019 7:11 am
Also, DV does not currently work in the MKV container.
