Firmware downgrade using official (patched) flasher, the "Ultra hax0r guide"
cappy1
Re: Firmware downgrade using official (patched) flasher, the "Ultra hax0r guide"
Post by cappy1 » Mon Jul 01, 2019 1:25 pm
My 2017 Asus BW-16D1HT successfully ripped about 70 UHD disks since last year, but the triple-layered UHD Black Hawk Down wouldn’t rip, saying drive or disk was bad. I had read that my drive had issues with triple layers, so I bought a new LG WH16NS60 and downgraded it to FW 1.00 using Billy’s video instructions.
Well, Black Hawk Down wouldn’t rip on the LG after going about 40%. Frustrated, I got another copy of the movie and it still wouldn’t rip. :|
I read somewhere on the Forum that HK might be a little more friendly to triple layers. Thus, is it possible to change the LG from DE to HK? If so, how?
Post by d00zah » Mon Jul 01, 2019 3:03 pm
cappy1 wrote: Mon Jul 01, 2019 1:25 pm I read somewhere on the Forum that HK might be a little more friendly to triple layers. Thus, is it possible to change the LG from DE to HK? If so, how?
MK FWs are typically latest/greatest for a particular drive with microcode access re-enabled. Whether it "might be a little more friendly to triple layers", or not, depends largely on what the latest/greatest was supposed to fix (mfgr FW release notes). All compiled UHD info here:
viewtopic.php?f=16&t=19634
cappy1
Post by cappy1 » Mon Jul 01, 2019 5:40 pm
Thanks, but I can't find anything in the links provided that deal with my specific question, (or I am too ignorant to recognize them).
I already downgraded my LG WH16NS60 to FW 1.00, but I want to try MK in hopes of improving 3 layer rip results. Can I simply flash the appropriate MK file, or do I first have to revert back to FW 1.01 (if possible)?
cappy1
Post by cappy1 » Mon Jul 01, 2019 9:57 pm
Thanks, I just switched over to "MK" and no improvement. Two UHD disks and two different drives and still can't rip. :|
JensenJ
Post by JensenJ » Wed Jul 03, 2019 11:09 am
Hi All,
I just purchased an LG BH-16NS55 with firmware version 1.04. I was wondering if;
A) I have not seen any reference to this firmware version, should I make a backup before I flash to 1.02? Do I need to do this anyway?
B) Has anyone with version 1.04 flashed their drive successfully?
C) Will the LG flasher (N1.00-A4) tool work with this firmware version (attached screenshot) or is there a better tool?
Any advice will be appreciated.
Thank you all.
Post by Billycar11 » Wed Jul 03, 2019 7:45 pm
JensenJ wrote: Wed Jul 03, 2019 11:09 am Hi All,
Read the Newer OEM Firmwares section on the second post d00zah linked
bear2019
Post by bear2019 » Wed Jul 10, 2019 7:18 am
I'm having trouble with the LG BH16NS55. I start the application and choose my bin file, but after clicking start, it gives me and error. The drive is still in working order after. Any help is appreciated.
st4evr
Post by st4evr » Wed Jul 10, 2019 2:20 pm
bear2019 wrote: Wed Jul 10, 2019 7:18 am Hello,
You need to provide additional information.
What is the exact error being presented?
What is happening exactly?
This is an online forum. Simply saying “it does not work” does not help. We are not sitting next to you nor are we mind readers. Help us help you.
bear2019
Post by bear2019 » Wed Jul 10, 2019 4:27 pm
hello thank you for replying- i think the error is Write DRAM NG i watched the youtube video (latest) downloaded the installer I chose my bin. It does not go to percentage complete- as soon as I press play it comes up with this error. The drive is installed in the computer, i even tried the Asus firmware installer with the correct bin, still no luck. Like i said the drive is still in working order. Thank you
Post by MartyMcNuts » Wed Jul 10, 2019 11:30 pm
Please provide some details. Simply saying that is of no help at all. Let's start with...
1. What OS are you using?
2. What firmare does your drive have? If it is 1.04, you must flash ASUS BW-16D1HT 3.10-MK first, then you can flash whatever firmware you like.
3. What flashing tool are you using?
4. What error are you getting?
5. How is your drive connected to your PC?
6. Do you have any other software running that uses the drive (MakeMKV, AnyDVD or any other disc accessing software)?
Cheers.
moomoo
Post by moomoo » Mon Jul 15, 2019 1:20 pm
Thanks for all of the great work people have done on this.
I have a BU40N which came flashed with FW 1.0.3.
I have connected the drive to my laptop via a USB - Slimline SATA adapter (in case that makes a difference)
I am running Windows 10 X64 Pro
I have tried to follow the YouTube video https://www.youtube.com/watch?v=Yfpf6HoMMis
I downloaded the Downgrade Enabled Firmware with Unlocked Flasher:
https%3A%2F%2Fdrive.google.com%2Ffile%2Fd%2F102V7DUp45TkU-mYgu992F3NHLNEmeZTN%2Fview%3Fusp%3Dsharing
I run the flasher as Administrator
Flasher detects my drive and current FW version correctly :)
I browse for the relevant FW: DE_LG BU40N_1.00.bin
I press the flash button
I get the error
Write DRAM NG
05/26/03
Anyone know what I am doing wrong?
Thank you in advance.
Moo
Post by Billycar11 » Mon Jul 15, 2019 8:10 pm
moomoo
Post by moomoo » Tue Jul 16, 2019 2:58 am
Thanks Billycar11,
I've downloaded the 1.03 MK firmware from the second thread you shared
I will change my setup in that I will connect the BU40N directly to the SATA port (not via USB)
Am I correct in thinking that I should flash to 1.03 MK and then to the 1.00 FW?
Also - what does MK mean - see the term everywhere but not the full meaning.
Thanks again.
Amasakre
Post by Amasakre » Tue Jul 16, 2019 1:34 pm
Billycar11 wrote: Wed Feb 06, 2019 12:37 am nice thank you so much for this
How to video: https://www.youtube.com/watch?v=Yfpf6HoMMis
Included in this zip is the following firmware:
ASUS_BW-16D1HT_302
BE16NU50_1.01
BH14NS50_1.01
BH14NS58_1.00
BH16NS40_1.02_NS50
BH16NS50_1.01
BH16NS55_1.02
WH14NS40_1.02_NS50
WH16NS40_1.02_NS50
BU40N_1.00
WH16NS60_1.00
Buffalo BRUHD-PU3 BU10 Thanks to
flashback8 wrote:
for the Buffalo BRUHD-PU3 BU10 Dump This is the firmware file name DE_flash_HL-DT-ST_BD-RE_BU40N_BU10.bin
they all have the downgrade enabled so all you need to do is download this and the unlocked flasher and then choose the file for your drive. This works with SATA AHCI/RAID, IDE, and over USB!!
Big thanks to
mike admin wrote: Wed Feb 06, 2019 12:17 pm
for letting us know where to edit
And Big thanks to
Blackened2687 wrote: Wed Feb 06, 2019 6:53 am
for the Unlocked Flasher :D :D
Downgrade Enabled Firmware V.2
https://drive.google.com/file/d/102V7DU ... sp=sharing
MD5: D9166F375D82D808411549BF615EE70E
SHA-256: 64084863829C3C8EFABF6ED786DAC426AC70C23AE02D7525C36C369841C869B0
How can i downgrade Buffalo BRUHD-PU3 with BU12 to BU10?
I cant get it to work :/
Locked
