Grencola
#451 Post by Grencola » Tue Jun 25, 2019 3:24 am
Alldu wrote: Mon Jun 24, 2019 4:30 pm Hi Grencola,
I've just discovered your program, and by the look of it, it's just what I need! However, this link isn't working anymore, so is there a way I can obtain this excellent tool? Thanks so much in advance!
https://bit.ly/2WbHZR0
Alldu
#452 Post by Alldu » Tue Jun 25, 2019 1:09 pm
Grencola wrote: Tue Jun 25, 2019 3:24 am
Thanks so much! I was just wondering - if I want to add subtitle file after I've made mp4, I just do it as usual - via MKVtoolNix? No tricks here? :)
Alldu
#453 Post by Alldu » Tue Jun 25, 2019 4:32 pm
benhur wrote: Tue Jun 25, 2019 4:15 pm You can't add subtitle into mp4.
To have movie and subtitle, you need to make a .srt file (with the exact same name as the movie) and place it in the same folder as the movie.
Normally the srt file should be read by the player. (It works on LG) :wink:
Right, dumb me! MKV is a container while mp4 is not... Thanks! But is there a way you can combine (mux?) an mp4 and a graphic-based subtitle file, such as SUB/IDX, so that the the player read the subs as it usually does with .mkv? Would putting SUB/IDX and mp4 in one folder be the solution?
Grencola
#454 Post by Grencola » Tue Jun 25, 2019 6:17 pm
Alldu wrote: Tue Jun 25, 2019 1:09 pm Thanks so much! I was just wondering - if I want to add subtitle file after I've made mp4, I just do it as usual - via MKVtoolNix? No tricks here? :)
Use this: https://bit.ly/2OYwutN it will give you English subtitles along with your mp4.
Alldu
#455 Post by Alldu » Tue Jun 25, 2019 7:51 pm
Grencola wrote: Tue Jun 25, 2019 6:17 pm
Thanks again! It works with .srt files only? Or with graphic-based - such as SUB/IDX?
Grencola
#456 Post by Grencola » Tue Jun 25, 2019 10:54 pm
Alldu wrote: Tue Jun 25, 2019 7:51 pm
no prob man. should work with everything SubtitleEdit supports; pgs, sub, ocr, srt, etc..
Alldu
#457 Post by Alldu » Wed Jun 26, 2019 8:40 am
Grencola wrote: Tue Jun 25, 2019 10:54 pm
So cool! thanks a lot!
Redhawk2000
#458 Post by Redhawk2000 » Sun Jun 30, 2019 12:08 am
Anyone have any idea if the newer lg c9 with HDMI 2.1 and eARC would be able to play full DV disc rips via USB or Ethernet and then output (via eARC) lossless audio to a receiver?
I ask because I just ordered a c8 on sale but would cancel it if the above was a maybe.
#459 Post by SamuriHL » Sun Jun 30, 2019 1:37 am
It does have eARC so that's a definite maybe. You, of course, also need a receiver that can support it. But I don't know if their LG player supports doing so.
Redhawk2000
#460 Post by Redhawk2000 » Sun Jun 30, 2019 2:46 am
SamuriHL wrote: Sun Jun 30, 2019 1:37 am It does have eARC so that's a definite maybe. You, of course, also need a receiver that can support it. But I don't know if their LG player supports doing so.
Didn't even think of the receiver needing to support eARC. Was just thinking of it handling lossless codecs. Good point. Guess that would be a whole other issue.
Alldu
#461 Post by Alldu » Tue Jul 02, 2019 10:30 pm
Hi Grencola, so I tried your subtitles tool on Spider-Man Homecoming and unfrotunately it gives me an error:
This subtitle conversion is not supported.
This file does not contain a Dolby Vision video track. Try another file!
THis is an .m2ts file, and then I try the usual dv-mp4-maker on it, it makes a perfect mp4 with Dolby Vision. Any idea what am I doing wrong? Many thanks!
Grencola
#462 Post by Grencola » Tue Jul 02, 2019 10:55 pm
Alldu wrote: Tue Jul 02, 2019 10:30 pm
weird, SubtitleEdit seems to struggle with zib subs, I haven't seen them before either. just extract this: https://subdl.com/subtitle_dl.php?p=L3N ... 8xNzg0NTMx into your movie folder and rename it to match your mp4.
https://subdl.com usually has it if you can't make one.
Alldu
#463 Post by Alldu » Wed Jul 03, 2019 10:19 am
Grencola wrote: Tue Jul 02, 2019 10:55 pm
Hmm, sorry, don't want to be "that guy", but it still isn't working... I uploaded the subs you've shared to the folder where m2ts file was and renamed it, still same error...
Grencola
#464 Post by Grencola » Wed Jul 03, 2019 1:22 pm
Alldu wrote: Wed Jul 03, 2019 10:19 am Hmm, sorry, don't want to be "that guy", but it still isn't working... I uploaded the subs you've shared to the folder where m2ts file was and renamed it, still same error...
put it in the same folder as your dv mp4. make the .srt and the .mp4 the exact same filename. play your mp4 and you will get subs. might have to enable them during playback depending on device.
Grencola
#465 Post by Grencola » Wed Jul 03, 2019 2:32 pm
Redhawk2000 wrote: Sun Jun 30, 2019 12:08 am Anyone have any idea if the newer lg c9 with HDMI 2.1 and eARC would be able to play full DV disc rips via USB or Ethernet and then output (via eARC) lossless audio to a receiver?
You'll only get HDR10 if you try this. You either need an Oppo uhd-bd player (or its clone), or a converted MP4 to get Dolby Vision, the latter only has lossy audio. The Matroska devs are working on an MKV update to support Dolby Vision, but there's no ETA as of yet.
