Very often, BRs have a lot of audio and subs tracks, and generally you just want one.
Currently (if I'm not mistaken), you have to disable the unwanted tracks one by one.
It would be nice to have a button, or a function key, to disable every audio and subs tracks, so that then just would just need 2 clicks to enable what you want.
Some disks can require 20 or 30 clicks to remove unwanted tracks.
[Solved] Remove all audio and subs tracks at once
Re: [Feature Request] Remove all audio and subs tracks at once
Right-click on the '... disc' header, or any individual title (left-hand pane) & select the desired option.
Thanks, I did not notice that there was such a menu.
I found a better way: Use the following string:
-sel:all,+sel:video
in the default selection rules in the Advanced tab.
Nothing to do, and all the titles remain selected with BRs holding series.
-sel:all,+sel:video
Re: [Solved] Remove all audio and subs tracks at once
There's that, too. ![Smile :)](./images/smilies/icon_smile.gif)
For Mac users, Control-click the top level of the disc on the left side once it becomes available.
You can then pick either Select All or Deselect All.
