[Solved] Remove all audio and subs tracks at once
BobLSL
Post by BobLSL » Mon Jun 24, 2019 9:46 pm
Very often, BRs have a lot of audio and subs tracks, and generally you just want one.
Currently (if I'm not mistaken), you have to disable the unwanted tracks one by one.
It would be nice to have a button, or a function key, to disable every audio and subs tracks, so that then just would just need 2 clicks to enable what you want.
Some disks can require 20 or 30 clicks to remove unwanted tracks.
Re: [Feature Request] Remove all audio and subs tracks at once
Post by d00zah » Mon Jun 24, 2019 10:15 pm
Right-click on the '... disc' header, or any individual title (left-hand pane) & select the desired option.
BobLSL
Post by BobLSL » Mon Jun 24, 2019 11:18 pm
Thanks, I did not notice that there was such a menu.
BobLSL
Post by BobLSL » Mon Jun 24, 2019 11:30 pm
I found a better way: Use the following string:
-sel:all,+sel:video
in the default selection rules in the Advanced tab.
Nothing to do, and all the titles remain selected with BRs holding series.
Re: [Solved] Remove all audio and subs tracks at once
Post by d00zah » Mon Jun 24, 2019 11:43 pm
There's that, too. :)
philb1701
Post by philb1701 » Sun Jan 19, 2020 9:06 am
For Mac users, Control-click the top level of the disc on the left side once it becomes available.
You can then pick either Select All or Deselect All.
