Bumblebee bluray help
diy_darryl
Post by diy_darryl »
I have not used mkv for some time.
Just ripped 2 blurays with no problems. Bumblebee bluray fails and I don't know why.
I am seeing new things about libredrive, is that my issue or is that only for 4K which I will never rip?
A lot of this is over my head so in layman's terms if you could be so kind please?
I tried a full disc backup as a last resort when this file was created I believe, but failed 2 previous attempts to rip.
Thank You.
My drive is a pre-2015 WH14NS40 and DOES NOT have an NS50 svc code on it. Will this drive continue to work as long as I am not ripping 4K discs or do I need to upgrade?
Debug log started at Thu Jun 20 13:55:16 2019 , written by MakeMKV v1.14.4 win(x64-release)
001005:0000 MakeMKV v1.14.4 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Darryl.Office/MakeMKV_log.txt
SDF v05c: HL-DT-ST_BD-RE__WH14NS40_1.03_211403261105_K99D75G0822
005072:0000 Backing up disc into folder "M:\Movies4a\/backup/Bumblebee"
001011:0000 LibreDrive firmware support is not yet available for this drive (id=BF04C03F631B)
DEBUG: Code 2317353423 at }yJ2^mTS!\xYjfa7w:121264096
DEBUG: Code 0 at }yJ2^mTS!\xYjfa7w:121264119
DEBUG: Code 1 at }yJ2^mTS!\xYjfa7w:121264119
DEBUG: Code 2 at }yJ2^mTS!\xYjfa7w:121264119
DEBUG: Code 3 at }yJ2^mTS!\xYjfa7w:121264119
DEBUG: Code 4 at }yJ2^mTS!\xYjfa7w:121264119
DEBUG: Code 5 at }yJ2^mTS!\xYjfa7w:121264119
DEBUG: Code 2317353423 at }yJ2^mTS!\xYjfa7w:213132652
DEBUG: Code 0 at Eq;$'9@sIM#MW%j~k(V:29402325
DEBUG: Code 3 at %A0\=b]TRP7iUuct:29407753
DEBUG: Code 0 at Eq;$'9@sIM#MW%j~k(V:121270582
DAFD=PAAAADAAAAEABDQkEFwECAQ==
DCE=u32sKv61cd5Hi34BAE9lHI0GdtpIatPbz5lggZJUy5k8Stbc/BLaSEeYN6hmElJj/IvY4HAXWsGPUODq/LqZFFuDjCsL+HBeYHTYgMcK/lA8mU5YDwIzERmh/uAjSHalwbAfS9zl1jRbp+TSQw1zoIM41MT7VqvF1Q==
DCE=Wwzd8nF4An1BJo7ZIt/YdHf821gCGtj7lBIqFtMUpyH7SK3aWVoyJtCmlJDADNLNFxZwPfv83d563CTlIKyswkt9+i8UjUVW0CVRl4Ypn2LSwEMdxavDOYSL82EIBl2ihBRRXfND6R0O81jD7wjj+veOmY1MEcD3QQ==
001003:0020 DEBUG: Code 3221225628 at 2)Me.@84\|r*6W&&&97..1e^:29394091
001003:0020 DEBUG: Code 3221225628 at e7]KVtM7J@G@6#ej:121262417
001003:0020 DEBUG: Code 100864261 at Lt[RKo\%gO`]aK^U:213137574
001003:0020 DEBUG: Code 100864261 at e7]KVtM7J@G@6#ej:121262417
005076:0000 Hash check failed for file 00800.m2ts at offset 23038126080, file is corrupt.
005076:0000 Hash check failed for file 00800.m2ts at offset 23038519296, file is corrupt.
005076:0000 Hash check failed for file 00800.m2ts at offset 23038715904, file is corrupt.
005076:0000 Hash check failed for file 00800.m2ts at offset 23038912512, file is corrupt.
005076:0000 Hash check failed for file 00800.m2ts at offset 23039109120, file is corrupt.
005077:0000 Too many hash check errors in file 00800.m2ts.
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00800.m2ts' at offset '25610809344'
001003:0020 DEBUG: Code 0 at Eq;$'9@sIM#MW%j~k(V:29397679
001003:0020 DEBUG: Code 0 at Eq;$'9@sIM#MW%j~k(V:121265131
001003:0020 DEBUG: Code 0 at %|%amsW&?6)?KD^2ja8o:29396920
002023:0000 Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=17 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
002023:0000 Encountered 9083 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/
error=0x070B0BBB count=9083 name=Internal error - M2TS hash check failed (3003)
Encountered 4 unclassified errors
error=0xC000009C count=4 name=OS error - STATUS_DEVICE_DATA_ERROR
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Thu Jun 20 18:57:35 2019
Re: Bumblebee bluray help
The relevant log entries are summarized above - there is an issue with the disk. Probably needs cleaning.
This is a good place to start: viewtopic.php?f=8&t=15055
diy_darryl
Thank You for the explanation. I wish I understood the debug file but I don’t.
Bossi
Post by Bossi »
Same problem with Bumblebee Bluray.
Disk is clean and free of scratches.
BR-Drive works finde, no problems with other disks...
