Cannot copy any dvds on linux mint
Wiztech36
Post by Wiztech36 » Tue Jun 18, 2019 6:27 am
I am trying to copy some of my dvds to my linux hard drive and im unable to. Everytime time i try i get failed to copy along with these errors MakeMKV v1.14.4 linux(x64-release) started
Automatic checking for updates is enabled, you may disable it in preferences if you don't want MakeMKV to contact web server.
Downloading latest SDF to /home/joe/.MakeMKV ...
Title #1 was added (8 cell(s), 0:23:35)
Title #2 was added (8 cell(s), 0:23:35)
Title #3 was added (7 cell(s), 0:23:39)
Title #4 was added (7 cell(s), 0:23:36)
Title #5 was added (7 cell(s), 0:23:38)
Title #6 was added (7 cell(s), 0:23:36)
Title #7 was added (7 cell(s), 0:23:36)
Title #8 was added (10 cell(s), 0:23:35)
Title #9 was added (61 cell(s), 3:08:50)
Saving 1 titles into directory /home/joe/Videos/HOME_IMPROVEMENT_DISC2
Unable to execute external program 'ccextractor' as its path is not set in preferences
Failed to execute external program 'ccextractor' from location '/usr/bin/mmccextr'
Failed to save title 0 to file /home/joe/Videos/HOME_IMPROVEMENT_DISC2/title_t00.mkv
0 titles saved, 1 failed
None of my dvds will copy. I am a registered makemkv member. I am using linux mint 19.1. If you need more information let me know just so you know i am not that good on linux like like using commands and sunch so if i gotta do something on my end ill try whatever it takes. Im using makemkv 1.14.4.
Re: Cannot copy any dvds on linux mint
Post by Woodstock » Tue Jun 18, 2019 12:54 pm
The Linux version does not include the ccextractor program to extract Closed Captions, expecting it to already be installed on your system. If the disk you're trying to rip has Closed Captions, the default selection rule will attempt to rip them, but you don't have the program to do it, so it fails.
You can test this by unselecting the CC tracks from each title.
Some additional information here: https://www.makemkv.com/forum/viewtopic.php?t=18285
Information on ccextractor here: https://www.ccextractor.org/
Wiztech36
Post by Wiztech36 » Tue Jun 18, 2019 8:09 pm
Ok i did test it by unselecting cc and it works. I did follow someone steps to setup ccextractor on linux i followed the steps right and it said no issues. I did pinpoint makemkv to my ccextractor in makemkv directory and it still came up with the closed caption error.
i followed this thread https://www.makemkv.com/forum/viewtopic ... 2&start=15 and still closed caption error I was hoping to copy closed captions from makemkv since im hard of hearing. I was hoping to do it all in one steps.
moreshining
Post by moreshining » Sun Dec 15, 2019 3:34 pm
Are you still getting this error? I also am on Linux Mint, and wanted to get CC in one step. It took a bit of fiddling with ccextractor, but I did get it all working correctly.
in order to get ccextrator installed, i followed the directions at https://github.com/CCExtractor/ccextrac ... stallation
I did it all from the command line -- if you're not super familiar with command line, the wiki has most of it, but I did get a couple redirected package locations. the error messages had what I needed to correct things, so read them carefully.
then set the ccextractor location in the makemkv preferences, and hey presto, close captions.
