This is what I found during the movie AVATAR (Italian)
I think the problem is due to some bugs, this problem shows some frames.
PROCEDURE MakeMKV
These are frames of reference
Frame 2:06:53 (it is not the subforced)
Frame at 02:30:37 (subforced appears on the next frame of 02:30:51)
2:30:51 frame (it is not the subforced for this frame)
PROCEDURE MKVToolnix
With this procedure, the subtitles are correct
Frame 02:06:53
Frame 02:30:51
Subtitles not synchronized
Zidoo Z9X | HiMedia Q5 Pro and Q10 Pro | ZDMC 20.1 | Remote WeChip | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C
My PC Ryzen 7950X
My PC Ryzen 7950X
- Contact:
Re: Subtitles not synchronized
Do you run MKVToolnix on MKV file produced by MakeMKV, or on decrypted M2TS file? Is the subtitle before or after correct frame?
MakeMKV was carried out by Blu-ray already decrypted (so full) to the HDD, the same procedure was performed with MKVToolnix.
Are two independent procedures.
The subtitle, in this example, appears before the correct frame.
In other situations also appears later.
My PC Ryzen 7950X
My PC Ryzen 7950X
