Modify Default Behavior? / Subtitles?
Krawk
Post by Krawk »
Consider this a feature request as I currently do not see it as an option.
When I rip discs, I generally always turn OFF the subtitles before doing so. I realize that they don't take up much space but that is my preference. I would ask that we can either save a default preference to enable or disable the checkboxes for subtitles. If not, what is everyone's thoughts on changing the built in default behavior to have subtitles turned OFF by default?
Re: Modify Default Behavior? / Subtitles?
Post by d00zah »
https://www.makemkv.com/forum/viewtopic.php?f=10&t=4386
- Check MakeMKV preferences General > Expert mode
- Restart MakeMKV
- Add custom selection rule to MakeMKV preferences > Advanced > Default selection rule
Example:
-sel:all,+sel:audio&(favlang),-sel:mvcvideo,+sel:subtitle&(favlang),=100:all,-10:favlang
If you want NO subtitles selected by default, try:
