Freewareorary key has expired and was removed...
Locked
dasman
Post by dasman » Sun Sep 12, 2010 1:05 am
I installed MakeMKV about a month ago and today went to use it and rec'd the following error dialog:
MakeMKV BETA popup
Freewareorary key has exprired and was removed. Please restart the application.
I hit ok, the dialog closes and I try to restart MakeMKV, only to receive the same error message. I assume I need to enter either a BETA key or a purchased key, but if the software doesn't open, how do I enter a key? I tried searching thru the registry with REGEDIT, but didn't see anything that seemed obvious...
I have tried uninstalling the software, rebooting and then reinstalling, only to receive the same error. I am running Win7x64.
I appreciate the help, I have come to depend on the application.
Thanks,
dave steele
MR.WaynesWorld
Re: Freewareorary key has expired and was removed...
Post by MR.WaynesWorld » Sun Sep 12, 2010 1:08 am
I'm getting the same error message. Normally a new Beta release comes out and I install that one.
MR.WaynesWorld
Post by MR.WaynesWorld » Sun Sep 12, 2010 1:11 am
As a matter of fact I just tried installing 1.5.8 of MakeMKV on another machine and same error. Expiration must be by date.
Is 1.5.9 coming soon?
oscillator
Post by oscillator » Sun Sep 12, 2010 1:45 am
You can set the clock back a few days on your pc until they resolve the issue.
dvdluvver73
Post by dvdluvver73 » Sun Sep 12, 2010 1:54 am
I just grabbed the new key (says it's good 'til october), set my clock back, ran the program, registered w/ the new key, restarted the program, returned my clock to present time and it worked again!
dasman
Post by dasman » Sun Sep 12, 2010 2:01 am
dvdluvver73 wrote:I just grabbed the new key (says it's good 'til october), set my clock back, ran the program, registered w/ the new key, restarted the program, returned my clock to present time and it worked again!
Perfect! Thank you
dave
MR.WaynesWorld
Post by MR.WaynesWorld » Sun Sep 12, 2010 2:05 am
Yes, Thank You....
Chopster
Post by Chopster » Mon Sep 13, 2010 4:09 pm
Can someone please tell me where do you grab the new key from.
Thanks in advance.
Chopster
Post by Chopster » Mon Sep 13, 2010 4:17 pm
Ok sorted now found the key it works fine.
for info here's the key- T-kQ8lHCLcluYdZUHqy5T85oGo3vMXm31MyqAFlAKul2pGyIGY4PmRHWpRxUyhf4xbkS
Post by mike admin » Tue Sep 14, 2010 6:52 am
Please see the very first sticky topic on this forum :)
Locked
