I installed MakeMKV about a month ago and today went to use it and rec'd the following error dialog:
MakeMKV BETA popup
Freewareorary key has exprired and was removed. Please restart the application.
I hit ok, the dialog closes and I try to restart MakeMKV, only to receive the same error message. I assume I need to enter either a BETA key or a purchased key, but if the software doesn't open, how do I enter a key? I tried searching thru the registry with REGEDIT, but didn't see anything that seemed obvious...
I have tried uninstalling the software, rebooting and then reinstalling, only to receive the same error. I am running Win7x64.
I appreciate the help, I have come to depend on the application.
Thanks,
dave steele
Freewareorary key has expired and was removed...
MR.WaynesWorld
Re: Freewareorary key has expired and was removed...
I'm getting the same error message. Normally a new Beta release comes out and I install that one.
MR.WaynesWorld
As a matter of fact I just tried installing 1.5.8 of MakeMKV on another machine and same error. Expiration must be by date.
Is 1.5.9 coming soon?
oscillator
You can set the clock back a few days on your pc until they resolve the issue.
dvdluvver73
I just grabbed the new key (says it's good 'til october), set my clock back, ran the program, registered w/ the new key, restarted the program, returned my clock to present time and it worked again!
Perfect! Thank youdvdluvver73 wrote:I just grabbed the new key (says it's good 'til october), set my clock back, ran the program, registered w/ the new key, restarted the program, returned my clock to present time and it worked again!
dave
MR.WaynesWorld
Yes, Thank You....
Can someone please tell me where do you grab the new key from.
Thanks in advance.
Ok sorted now found the key it works fine.
for info here's the key- T-kQ8lHCLcluYdZUHqy5T85oGo3vMXm31MyqAFlAKul2pGyIGY4PmRHWpRxUyhf4xbkS
- Contact:
Please see the very first sticky topic on this forum
