Just picked up the new UHD Fast & Furious Collection. Just tested out Fast & Furious 6 and there's no volume key for the disc in my set yet.
MKB20_v61_Fast_and_Furious_6_E625
Dump submitted. Thanks!
Fast & Furious 6
Swaps
Re: Fast & Furious 6
Couldn't get disc one to decrypt
jayper
It's probably worth submitting the dump file, if you hadn't already. I'll check my disc tonight.
Swaps
I sent disc 1. Disc 2 working fine. I'll update as I go through them.
mutelight
Awesome, thank you!Swaps wrote: Wed Jun 12, 2019 11:32 pm I sent disc 1. Disc 2 working fine. I'll update as I go through them.
I ran into the same issue with Disc 1 last night and was willing to submit dumps but if you are already on it, I won't duplicate your effort.
jayper
Just submitted a dump for disc 1 as well. I'll do the same!Swaps wrote: Wed Jun 12, 2019 11:32 pm I sent disc 1. Disc 2 working fine. I'll update as I go through them.
jayper
It's actually a good idea to duplicate efforts in this case. There is not 1 code per movie. There are often several codes for each movie.mutelight wrote: Wed Jun 12, 2019 11:33 pmAwesome, thank you!Swaps wrote: Wed Jun 12, 2019 11:32 pm I sent disc 1. Disc 2 working fine. I'll update as I go through them.
Swaps
Submitted dumps for 1,3,6,7,8.
mutelight
Gotcha, I absolutely will then!jayper wrote: Thu Jun 13, 2019 12:48 amIt's actually a good idea to duplicate efforts in this case. There is not 1 code per movie. There are often several codes for each movie.mutelight wrote: Wed Jun 12, 2019 11:33 pmAwesome, thank you!Swaps wrote: Wed Jun 12, 2019 11:32 pm I sent disc 1. Disc 2 working fine. I'll update as I go through them.
Sorry for the noob question but how do I submit it?
Email it to svq at makemkv dot com
EROracing
where do I send these dump files to 1,3,6,7 and 8 failed to decrypt disc?
st4evr
Read this thread:EROracing wrote: Mon Jun 17, 2019 3:05 am where do I send these dump files to 1,3,6,7 and 8 failed to decrypt disc?
https://www.makemkv.com/forum/viewtopic ... 12&t=19752
Provides the information you are looking for.
jayper
First of all, thanks Mike!
FYI to those following the thread, my versions of the following just successfully decrypted:
F&F 1
Toky Drift
F&F 6
F&F 7
Everything else in the collection worked last week.
F&F 1
Toky Drift
F&F 6
F&F 7
