MKB_v4_unkn0wn_2E70
squids
MKB_v4_unkn0wn_2E70
#1 Post by squids » Fri Jun 07, 2019 1:28 pm
MakeMKV v1.14.3 win(x64-release) started
The program can't find any usable optical drives.
Opening files on harddrive at E:/CHIEDI ALLA POLVERE
Downloading latest HK to C:\Users\xenxi/.MakeMKV ...
Saved AACS dump file as C:\Users\xenxi/.MakeMKV/MKB_v4_unkn0wn_2E70.tgz
DEBUG LOG:
Debug log started at Fri Jun 07 12:58:40 2019 , written by MakeMKV v1.14.3 win(x64-release)
001005:0000 MakeMKV v1.14.3 win(x64-release) started
005042:0000 The program can't find any usable optical drives.
003006:0000 Opening files on harddrive at E:/CHIEDI ALLA POLVERE
DEBUG: Code 2147483648 at 3n|Kn0<$@PHq+zen:29397035
003338:0000 Downloading latest HK to C:\Users\xenxi/.MakeMKV ...
Please let me know if you need more info.
I don't have a BR drive available so I'm using a folder in windows 10 containing AACS / BDMV / CERTIFICATE
Is this normally an okay procedure?
I have used the search.
Re: MKB_v4_unkn0wn_2E70
#2 Post by Woodstock » Fri Jun 07, 2019 3:11 pm
You're missing a file that is generated by MakeMKV when ripping a backup. It's name is discatt.dat, and if you don't have it, you have to find a working volume key for the disk on internet, OR you need to use the original disk to create it.
viewtopic.php?f=12&t=17087&p=69984#p60530 has more information on creating the discatt.dat file yourself, but it does require access to a Bluray drive, preferably the one that created the backup you're working from.
And a BD drive would be a good investment, anyway. If you're not interested in UHD, there are a LOT of inexpensive USB and internal drives available.
squids
#3 Post by squids » Fri Jun 07, 2019 3:20 pm
Thanks for your reply, I appreciate it.
re discatt.dat
This is the contents of that file in MKB_v4_unkn0wn_2E70.tgz
V
Created by libdriveio v1.03[win(x64-release)] http://www.makemkv.com/libdriveio
!MakeMKV v1.14.3 win(x64-release) ü
unkn0wn
EDIT:
If it matters, I got the files using my PS4 using an FTP mod to transfer the 3 main blu-ray folders and their subfolders etc.
There is a linux mod for PS4 - perhaps I could install makemkv on that and try to rip an image.
I intend to buy a drive to run some tests but the ps4 is all I have for now.
#4 Post by MartyMcNuts » Sat Jun 08, 2019 4:13 am
squids wrote: Fri Jun 07, 2019 3:20 pm Thanks for your reply, I appreciate it.
re discatt.dat
V
unkn0wn
EDIT:
The problem is that you copied the still encrypted folders from the disc to a folder on your hard drive. Now there is no way to obtain the Volume ID from your folder.
You need to either supply MakeMKV a VUK for that disc or allow MakeMKV to read the disc directly so it can extract the Volume ID from the disc and calculate the VUK.
Is it possible to connect the PS4 to the PC and use it like a normal optical drive? Probably not....
