Just purchased a key...
alfke
Post by alfke » Sat Jun 01, 2019 7:32 pm
I'm a longtime beta user who decided to buy a key. Registration was flawless and easy. Activation was fast and perfect. No issues. No complaints.
Carry on...
traumapa
Re: Just purchased a key...
Post by traumapa » Thu Jun 06, 2019 3:09 am
I'm new to MKV, just downloaded a few days ago. Now software is asking for a key. How do I purchase as you mentioned?
Post by d00zah » Thu Jun 06, 2019 1:08 pm
traumapa wrote: Thu Jun 06, 2019 3:09 am Hello,
From the MakeMKV UI, Help > Purchase
Once you have the key, Help > Register
NoobieNobody
Post by NoobieNobody » Fri Jun 07, 2019 3:38 am
Hi
Same issue here but it won't let me do anything other that put in a key. Not sure how to purchase one?
Post by Woodstock » Fri Jun 07, 2019 4:46 am
Temporarily set your system DATE back to when the original key was valid; 28 May 2019 should work for version 1.14.3.
Start MakeMKV. After it starts, you can reset your system date to the current date.
Go to Help->Register, and enter the new key.
If it's a purchased (i.e., permanent) key, you won't have to do this again unless you re-install MakeMKV. Keep a copy of the permanent key email in a safe place (not on your computer) in case something wipes out your system.
BlueMac77
Post by BlueMac77 » Fri Jun 07, 2019 4:44 pm
alfke wrote: Sat Jun 01, 2019 7:32 pm I'm a longtime beta user who decided to buy a key. Registration was flawless and easy. Activation was fast and perfect. No issues. No complaints.
Carry on...
Been using MakeMKV for many years and it’s worth the investment. It’s a good, reliable app. It can also detect 11+ old blu-ray and dvd drives.
mhkendig99
Post by mhkendig99 » Fri Jun 07, 2019 5:57 pm
How / where do I purchase a key ???
Mike
Post by Woodstock » Fri Jun 07, 2019 6:40 pm
Within MakeMKV, click on Help->Purchase.
Otherwise, you can get to the same place with https://makemkv.com/buy/
AmishTrader
Post by AmishTrader » Thu Dec 19, 2019 10:53 am
If I buy a key, will it still work if I change from win 7 to linux mint. during purchase, it asked for my OS, is that just for Mike's info. Been using MKV several years and it's easily worth the $50. Thanks for making it free also!
Grauhaar
Post by Grauhaar » Thu Dec 19, 2019 11:22 am
The key works on any platform.
Good Luck :)
