Azur et Asmar: main cartoon only provides sound, not picture
With MakeMKV 1.5.7, the main file is only playing sound, but no picture. Did anyone could display it properly (data encryption is AACS 9...)
- Contact:
Re: Azur et Asmar: main cartoon only provides sound, not pic
You can use VLC player to play such file on OS X
I use VLC, but only get a sound file. The picture must be saved given the size of the file but not displayed (I use the latest version of VLC?
setarip_old
Hi!
Open tsMuxeR and drag and drop the main movie .M2TS onto it, then post all of the information from the tsMuxeR bottom window back here...
thank you, but can you be more explicit? I do not have such a folder on the blu-ray: the structure is as follows:
AACS
BDMV
CERTIFICATE
and BDMV is made of:
AUXDATA
BACKUP
BDJO
CLIPINF
index.bdmv
JAR
META
MovieObject.bdmv
PLAYLIST
STREAM
AACS
BDMV
CERTIFICATE
AUXDATA
BACKUP
BDJO
CLIPINF
index.bdmv
JAR
META
MovieObject.bdmv
PLAYLIST
STREAM
setarip_old
You'll find all of the .M2TS files in the "Stream" sub-folder (The largest .M2TS file is usually the main movie)...
