LOTR The Two Towers Extended Edition
agcarver
Post by agcarver »
Received the following error in debug mode while ripping disc 2. Disc 1 rips ok, but I have the same issue with Return of The King Extended Edition Disc 2. Any advice you have would be great. I've been trying every so often to get these to work when I have time, its the last of my Blu Ray Library I need to save.
Debug log started at Sun Sep 30 15:38:13 2012 , written by MakeMKV v1.7.71 darwin(x86-release)
001005:0000 MakeMKV v1.7.71 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/
002014:0000 Optical drive "DVD+R-DL HL-DT-ST DVDRW GA32N KC08" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-RE HL-DT-ST BD-RE BP06LU10 HL03" opened in DASPI v1.3 mode.
001003:0020 DEBUG: Code 117506160 at ''c-4/3TWcW33%ys+5:213132100
001003:0020 DEBUG: Code 117506160 at ''c-4/3TWcW33%ys+5:29393930
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP06LU10 HL03' at offset '1038336'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP06LU10 HL03' at offset '915456'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP06LU10 HL03' at offset '688128'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP06LU10 HL03' at offset '669696'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP06LU10 HL03' at offset '751616'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP06LU10 HL03' at offset '759808'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP06LU10 HL03' at offset '706560'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading 'BD-RE HL-DT-ST BD-RE BP06LU10 HL03' at offset '737280'
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/AACS/MKB_RO.inf' at offset '0'
001003:0020 DEBUG: Code 117506160 at ''c-4/3TWcW33%ys+5:29396575
002003:0000 Error 'Internal error - Operation was cancelled (112)' occurred while reading '/AACS/Content000.cer' at offset '0'
Application exited at Sun Sep 30 15:39:39 2012
njgura87
Re: LOTR The Two Towers Extended Edition
Post by njgura87 »
I'm having a similar issue, did you ever get this disc to rip? I've tried 3 different discs on 2 different drives but I can't get disc 2 of Return of the King to rip.
Since the post you are replying to is 7 years old, and a lot of people (including me) have ripped one of the multiple versions of this disk since then, it is likely your issue is different.
What type of errors are you seeing? Do you have debug logging enabled?
Grauhaar
Post by Grauhaar »
Not sure, but you posted something like "same error" in the "fatal Error - Program Aborted" thread?
Now in an other very very old thread, with "similar issue" ... sounds confusing, same error? same disc? same issue?
If you want help, please describe the problem always as good as possible (with log and Debug log) and not as "similar", because this does not help. Two thread's with different problems (except that the disc could not be ripped) is not "similar".
And as Woodstock already wrotes, the LOTR discs can be ripped without problems, in the disc(s) and drive are okay.
Good Luck :)
