Can't read AACS VID from disc
silentducky
#1 Post by silentducky » Tue Jun 04, 2019 8:56 pm
I am new to makemkv, when I tried to rip a bluray that I own I received this error.
MakeMKV v1.14.3 linux(x64-release) started
Backing up disc into folder "/root/Videos/backup/THE_DARK_TOWER_2017"
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID COMMAND OPERATION CODE' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Saved AACS dump file as /root/.MakeMKV/MKB_v63_THE_DARK_TOWER_2017_2130.tgz
Backup failed
I am running the program in a Debian stretch VM. I have assigned it 16 cores and 24Gb of ram. Is that enough cores/ram? I can dedicate more if needed. I have a dual xeon e5-2670 setup with a total of 64gb of ram. Also my drive is a Pioneer BDR-208D.
Any information to help resolve this issue will be appreciated.
Thank you,
Silentducky
aan3kk
Re: Can't read AACS VID from disc
#2 Post by aan3kk » Wed Jun 05, 2019 9:10 am
MakeMKV doesn't require much processing power or RAM. 2 cores and 4 GB are more than fine.
The problem you experience may be caused by how the VM is routing the BD-ROM drive into the VM.
If it is a 4K UHD Blu-ray you need a LibreDrive compatible drive.
silentducky
#3 Post by silentducky » Thu Jun 06, 2019 2:37 am
I ran the program on my host windows machine, It worked fine.
Thank you for your help.
