So many mistakes
nenamax1
So many mistakes
Post by nenamax1 »
Hello. I use the translator from Google because I do not speak English. I hope you can guess halfway what I want to tell you. My problem is no matter what Bluray, DVD I always get errors. It started and then it started. Have all drivers updated & all Windows updates. The disk are all I mean, all of them are in perfect condition. And I also bought the Bluray burner just 4 days ago. He also sees everything can play everything only MakeMKV shows me errors and that:
Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00022.m2ts' bei Offset '2495846400'
Fehler 'Betriebssystemfehler - STATUS_DEVICE_DATA_ERROR' trat auf während des Auslesens von '\Device\CdRom0' bei Offset '2495846400'
Re: So many mistakes
You removed the information about what drive you are using, but the errors you are getting are consistent with a USB-powered drive that is not getting enough power to run at the speeds MakeMKV can read. It shuts down, giving a read error, followed by device not available errors as it resets.
Make sure the drive has full power available. Plug it in to ports ON the computer, not on a hub, unless the hub has its own power supply. If the drive came with a "2 head cable", make sure both are plugged in to ports with full power available.
nenamax1
Post by nenamax1 »
I'll get exactly the same mistakes out again. No matter if I do it over Thunderbolt 3 or Usb 3.0 it comes out the same. What's funny yesterday about it had everything works well. Now it's not ok anymore. I've tried several blurays but the same thing happened.
