Grencola
#376 Post by Grencola » Sun Jun 02, 2019 4:28 am
tango306 wrote: Sat Jun 01, 2019 11:03 pm
Grencola wrote: Sat Jun 01, 2019 8:38 pm
tango306 wrote: Sat Jun 01, 2019 3:42 pm H.265 HEVC is lossy codec. Period.
But that is literally what UHD Discs use..
https://en.m.wikipedia.org/wiki/Ultra_HD_Blu-ray
<<Encoding: H.265/MPEG-H Part 2 (HEVC)>>
I’ve said that several times to you when we discussed on DV. It’s a common knowledge here.
Doesn’t change the fact that the codec is lossy.
Cool man. UHD Blurays are encoded with a lossy codec. I got it. 8) Anyway, imho, getting Dolby Vision AND 5000+ kbps Lossless audio+Atmos with a few megabits of video compression is waay better than having those 3 or 4 Mbps back but hearing 640kbps ac3, lol. If what I even said will work, I mean. Otherwise of course go with the lossless mp4 vs lossy mp4.
Donpablo80
#377 Post by Donpablo80 » Sun Jun 02, 2019 4:05 pm
Grencola wrote: Sat Jun 01, 2019 2:49 pm
tango306 wrote: Sat Jun 01, 2019 2:14 pm
Donpablo80 wrote: Sat Jun 01, 2019 1:43 pm
Yes, but you can't see the difference between this encode of 48,2 Mb/s or the remux of 52,7 Mb/s. I have been comparing it several times. Maybe this is a nice solution for tv's that don't play dual layer mp4.
Well, whether the difference is visible or not is different topic. And this is very dependent in viewing environment, equipment and viewer.
That's not true at all; HEVC is NOT just a lossy codec. It can be perfectly lossless. In fact, Blurays use HEVC :) This is also such minor compression, we're talking a few mbits, that he's right, you won't see that. Plus the benefit could be a HUGE; what's now stopping us from demuxing the new single layer dv video track, and then muxing it with the hd-audio + atmos track into a ts container to now get full playback we've been wanting without an Oppo?! Apple TV 4k running MrMC, the Sony X700 BDP, and some TV's with e-arc can playback dolby vision from single layer video files and they support hd audio. I'm pretty excited! :D
Tsmuxer doesn't reconize the single layer dvhe video track, so i can't mux it with the TrueHD Atmos audio track. Is there an other muxer to try with?
Grencola
#378 Post by Grencola » Sun Jun 02, 2019 8:16 pm
Donpablo80 wrote: Sun Jun 02, 2019 4:05 pm
Do you mean when demuxing? This: https://github.com/DolbyLaboratories/dl ... 64bits.exe will demux your mp4 and give you the single-layer video.hevc track. Then add that to tsmuxer. If you did that and you meant it isn't recognized (weird cuz it should be) then ffmpeg should work.
Donpablo80
#379 Post by Donpablo80 » Sun Jun 02, 2019 9:06 pm
Grencola wrote: Sun Jun 02, 2019 8:16 pm
I mean the compressed single layer Dolby vision track that DVDFab is creating.
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.05.06, BL+RPU
Codec ID : dvhe
Codec ID/Info : High Efficiency Video Coding with Dolby Vision
Duration : 2 h 23 min
Bit rate : 48,2 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23,976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.242
Stream size : 48,2 GiB (99%)
Encoded date : UTC 2019-06-01 06:28:37
Tagged date : UTC 2019-06-01 07:11:03
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Codec configuration box : hvcC+dvcC
#380 Post by MartyMcNuts » Mon Jun 03, 2019 12:07 am
I suggest using mkvtoolnix. Just change the extension to mp4 before muxing.
Grencola
#381 Post by Grencola » Mon Jun 03, 2019 2:16 am
Donpablo80 wrote: Sun Jun 02, 2019 9:06 pm
Video
Format : HEVC
Codec ID : dvhe
Color space : YUV
Bit depth : 10 bits
it would be something similar to this:
ffmpeg -i <audio-stream> -i <video-stream> -async 1 -c copy test.ts
I haven't used ffmpeg much though, so those triggers might not be right
generalmilk
#382 Post by generalmilk » Mon Jun 03, 2019 2:23 am
Hmm, I just thought all hope is lost according to Grencola's comment. I don't trust Sony and Kodi won't get license. However, if DVDFab can indeed convert dual layer DV into single layer DV, then Sony TV might have a chance. But, how is it possible?
hepe9
#383 Post by hepe9 » Mon Jun 03, 2019 11:06 am
And no exist other program can make single layer dolby vision without compression?
Grencola
#384 Post by Grencola » Mon Jun 03, 2019 2:16 pm
hepe9 wrote: Mon Jun 03, 2019 11:06 am And no exist other program can make single layer dolby vision without compression?
the only method was needing a Dolby CMU Workstation with Dolby Encoder Suite and an official license from Dolby to reauthor the film into a different container. Not entirely sure how DVDFab achieves this. I personally haven't been successful yet, but I'm also only using the trial version as I didn't want to spend hundreds of dollars if it doesn't actually work.
Grencola
#385 Post by Grencola » Mon Jun 03, 2019 2:18 pm
generalmilk wrote: Mon Jun 03, 2019 2:23 am Hmm, I just thought all hope is lost according to Grencola's comment. I don't trust Sony and Kodi won't get license. However, if DVDFab can indeed convert dual layer DV into single layer DV, then Sony TV might have a chance. But, how is it possible?
If your TV can play the single layer LG DV demos files then you might have a chance..
fib1985
#386 Post by fib1985 » Mon Jun 03, 2019 3:26 pm
Hi guys,
how to make an .mp4 dolby vision file from full blu ray iso using clonebd ?
hepe9
#387 Post by hepe9 » Mon Jun 03, 2019 4:38 pm
Donpablo80 where is the compression mode in dvdfab?
I use the trial and have only 3 attempts and i used 2
1º time I used the Passtrought MP4 and create a MP4 with dual layer DV, the 2º attempt I used the MP4 Dolby Vision and is very very rare, it takes long time and is a Passtrought too.
Where is the option in the menu what do you say?
Grencola
#388 Post by Grencola » Tue Jun 04, 2019 1:41 am
hepe9 wrote: Mon Jun 03, 2019 4:38 pm Donpablo80 where is the compression mode in dvdfab?
I'm in the exact same boat as you, trial version as well..
I ran my bdmv folder through uhd ripper and did the mp4.dolbyvision passthrough which gave me the same dual layer file mp4muxer would. I can't seem to make a single layer file though. Donpablo80 said it has to be compressed, but when I go to advanced settings and uncheck Copy Video the few video quality toggles it has are all crazy compression, like 19887kbps :/ the Bits/Pixel slider is greyed out so I can't up the quality any higher. perhaps that's a benefit of the paid version?
hepe9
#389 Post by hepe9 » Tue Jun 04, 2019 3:52 am
Grencola wrote: Tue Jun 04, 2019 1:41 am
I used now the 3 attempts and nothing, the trial expired and nothing of compression mode and 1 layer in DV.
The program in trial version is like the can you purcharse but limited for 3 attempts only.
my love
#390 Post by my love » Tue Jun 04, 2019 4:33 am
It can convert the video to a small file size if uncheck the "Copy Video" option in the Advanced Settings, BUT I GOT THE SAME PROBLEM AS YOU. The max video bitrate is 19887kbps, and the DVDFab service told me that they will fix the problem in next new version. I used the video passthrough for now, and it played back well on my LG Dolby Vision TV. good luck :wink:
