Boy, wouldn't it sure be nice if a tool were made available to be able to do that....publicly.mike admin wrote: Thu Mar 28, 2019 11:46 pm emphasis mine. There are still few methods available, that work over USB![]()
Heads up - Support for LG UHD drives
Re: Heads up - Support for LG UHD drives
jonghotti
He said "tool" huh huh, huh huh.SamuriHL wrote: Fri Mar 29, 2019 12:12 amBoy, wouldn't it sure be nice if a tool were made available to be able to do that....publicly.mike admin wrote: Thu Mar 28, 2019 11:46 pm emphasis mine. There are still few methods available, that work over USB![]()
BinkIE1
I've read allot on the forum ... probably too much ... and am confused about what belongs where. (Would "archiving" the obsolete/old-info/wrong-info threads help?)
So, where do I stand with this (from the slim-drive label):
Thanks for any direction in this.
Is there (official?) software to give other needed information from this drive?HL Data Storage (Hitachi-LG) UHD Blu-ray / DVD Rewriter
ROM ver: 0415
model: BU50N
[barcode] RoHS
manufactured: May 2016
jonghotti
Hmm, this is a tough one. Is there a service code printed on the sticker on this drive? Actually no, if it says UHD Blu Ray it's gotta be the right generation. So firmware for the BU40N, version 1.00, either DE or MK will work on this drive. And that would be located in the first response here https://www.makemkv.com/forum/viewtopic ... 19&t=19113BinkIE1 wrote: Sun May 26, 2019 8:14 pm I've read allot on the forum ... probably too much ... and am confused about what belongs where. (Would "archiving" the obsolete/old-info/wrong-info threads help?)
ROM ver: 0415
model: BU50N
[barcode] RoHS
There may be firmware for the BU50N as well in there.
maxblack
I looked and that firmware pack by mike admin does have BU50N in it. And the modified LG Flasher that may help is well-buried in the drive.google link in this post:
https://www.makemkv.com/forum/viewtopic ... x0r#p70284
The flasher is (oddly) named this: BH14NS40_N1.00-A4_patched.exe !? but do not use the embedded fw of course.
Let us know if you proceed and are successful flashing your drive!
BinkIE1
Thanks guys!
[I'm pleased to discover I had noted-to-self your recommended threads ... and flagged the right firmware (for BU50N), but wrong updater (ASUS), from other threads.]
Now just run updater "BH14NS40_N1.00-A4_patched", load the proper firmware "HL-DT-ST-BD-RE_BU50N-1.00-NM00100-211711211006.bin" for the "DE" patch & MMKV updates ... and that's it in a single step? Excellent!
Is there any need (here) for this firmware version? Or if I need to restore the drive to it's original firmware, is one available (anywhere)?
BinkIE1
As I couldn't find my original firmware online (so far), to restore it in case something is needed from it in my day-to-day operations, I thought to test this on same-make-model-year, but flaky, drive. And it worked perfectly! Thanks again for the guidance, guys! If I can find my original firmware "0420" and can apply it back to the drive, that would be awesome ... and I'd immediately downgrade my good drive.
Unfortunately I couldn't further test it with MakeMKV as it's flakiness interfered with reading a UHD disc (same problem it always had with standard DVDs & Blu-rays).
You could use the old dosflash method to extract your firmware if you have the system requirements (and any required adapters).BinkIE1 wrote: Wed May 29, 2019 1:08 am As I couldn't find my original firmware online (so far), to restore it in case something is needed from it in my day-to-day operations, I thought to test this on same-make-model-year, but flaky, drive. And it worked perfectly! Thanks again for the guidance, guys! If I can find my original firmware "0420" and can apply it back to the drive, that would be awesome ... and I'd immediately downgrade my good drive.
BinkIE1
I was afraid of that. :O
I do have an old system (I think IDE was the key to using that method, from what I've noticed in browsing) ... but must do some digging to get it setup. Is there a best & fool-proof & up-to-date procedure, with step-by-step instructions, here?
SATA, with an 'IDE mode' setting in the BIOS.BinkIE1 wrote: Wed May 29, 2019 4:07 pm I was afraid of that. :O
I do have an old system (I think IDE was the key to using that method, ...
BinkIE1
That's right (I knew it was IDE-something)!Well, then, I might be able to use the laptop for the procedure. Thanks!
BinkIE1
An interesting thing ... I tried my flashed-but-flaky drive with DVDFab (1 month free trial) -- the drive kept getting stuck on the starting reads (as expected). Then I tried it with my nonflashed-and-good drive. Oddly enough, it ran without UHD-unfriendly errors. I was even able to copy a chapter off the disc in "MKV-passthru" format (a proper 4k rip, without the extra-junk of course
). So, what does that mean for the "unfriendly" BU50N and MakeMKV?
Are you sure that your current firmware on the good drive is UHD unfriendly? Have you tried to backup a UHD in makeMKV? Does makeMKV see the disc? Is libredrive enabled for the drive?BinkIE1 wrote: Fri May 31, 2019 5:36 pm An interesting thing ... I tried my flashed-but-flaky drive with DVDFab (1 month free trial) -- the drive kept getting stuck on the starting reads (as expected). Then I tried it with my nonflashed-and-good drive. Oddly enough, it ran without UHD-unfriendly errors. I was even able to copy a chapter off the disc in "MKV-passthru" format (a proper 4k rip, without the extra-junk of course). So, what does that mean for the "unfriendly" BU50N and MakeMKV?
BinkIE1
The first thing I tried was to test the drives in MakeMKV. The flashed, flaky-drive was ... flaky, so no info of any value there. Then I re-tried my working drive (not flashed) -- "retried" because, before all this, I tried MakeMKV and it didn't work on the 4k disc. My good drive always could read the 4k directory ..
(click for larger size)
.. but it couldn't do anything else. Thinking it need help, I started looking into friendly & unfriendly drives and firmwares, and such.
Then after all the firmware info and testing on the flaky drive, I tried my good drive in DVDFab ..
.. and it worked perfect. I saved a disc "chapter" and can play it fine on MediaPlayerClassic. By "fine" I mean sluggish on this laptop.
In my testing the 2 drives in MakeMKV, I noted it's information ..
.. but must've deleted the log file. So I just ran it again to get the "debug log" ..
(click for larger size).. but it couldn't do anything else. Thinking it need help, I started looking into friendly & unfriendly drives and firmwares, and such.
(click for larger size).. and it worked perfect. I saved a disc "chapter" and can play it fine on MediaPlayerClassic. By "fine" I mean sluggish on this laptop.
(click for larger size).. but must've deleted the log file. So I just ran it again to get the "debug log" ..
("max characters limit" -- continued in next post)Debug log started at Sat Jun 01 21:51:39 2019 , written by MakeMKV v1.14.3 win(x64-release)
001005:0000 MakeMKV v1.14.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\1/MakeMKV_log.txt
005072:0000 Backing up disc into folder "D:/MakeMKV/2001_ A Space Odyssey"
005050:0000 Evaluation version, 15 day(s) out of 30 remaining
No SDF v042: HL-DT-ST_BD-RE_BU50N_0420_211605241901_KZ7G62G2938
DEBUG: Code 0 at 3n|Kn0<$@PHq+zen:213140564
DEBUG: Code 0 at jFJ/sedl|n^h9"'$:29401014
DEBUG: Code 2147483648 at 3n|Kn0<$@PHq+zen:29397035
DAFD=PAAAADAAAAEABDQgEHwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 0 at 9feUnk3-Vsu(9Z;UE:213130766
001003:0020 DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:121263521
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at 9feUnk3-Vsu(9Z;UE:213130306
001003:0020 DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:213131709
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 1 at rl(}K"Hk=3WvG?cj-F:121263521
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 1 at rl(}K"Hk=3WvG?cj-F:213131709
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 2 at rl(}K"Hk=3WvG?cj-F:121263521
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 2 at rl(}K"Hk=3WvG?cj-F:213131709
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 3 at rl(}K"Hk=3WvG?cj-F:121263521
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 3 at rl(}K"Hk=3WvG?cj-F:213131709
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:213130904
001003:0020 DEBUG: Code 1 at rl(}K"Hk=3WvG?cj-F:213130904
001003:0020 DEBUG: Code 2 at rl(}K"Hk=3WvG?cj-F:213130904
001003:0020 DEBUG: Code 3 at rl(}K"Hk=3WvG?cj-F:213130904
001003:0020 DEBUG: Code 4 at rl(}K"Hk=3WvG?cj-F:213130904
BinkIE1
(continued from previous post)
So what do you make of this?DEBUG: Code 0 at 9feUnk3-Vsu(9Z;UE:213130306
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:213132721
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003332:0000 Saved AACS dump file as D:/MakeMKV/MKB20_v66_2001_A_Space_Odyssey_C6EF.tgz
003346:0000 LibreDrive compatible drive is required to open this disc - video can't be decrypted.
001003:0020 DEBUG: Code 0 at jFJ/sedl|n^h9"'$:29396115
001003:0020 DEBUG: Code 0 at g75u^zn^>U:IVZGA(]>:213141116
001003:0020 DEBUG: Code 0 at \njBo?vhlq/vib}6Jnjy:29396713
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Sat Jun 01 21:56:17 2019
