VLC, makemkv and BD+
legluondunet
Post by legluondunet »
I installed makemkv, use the libmmbd emulation to play my blu ray with VLC, all but the BD+.
VLC can not read BD+ with makemkv.
Is it a know issue?
VLC complained about a java error:
VLC media player 4.0.0-dev Otto Chriek (revision 4.0.0~rc1~~git20190303+r79643+178~ubuntu19.04.1)
[000055c3d29989c0] main libvlc: Lancement de vlc avec l'interface par défaut. Utilisez « cvlc » pour démarrer VLC sans interface.
dec.c:245: WARNING: using libmmbd for BD+. On-disc menus won't work with all discs.
[00007ff390000e60] libbluray access: First play: 1, Top menu: 1
HDMV Titles: 5, BD-J Titles: 86, Other: 0
bdj.c:861: Detected Java 9 or later JVM - support is experimental !
Exception in thread "main" PrintStream.java:java.io.PrintStream.println:899: java.lang.NoClassDefFoundError: org/objectweb/asm/commons/SimpleRemapper
PrintStream.java:java.io.PrintStream.println:899: 	at java.base/org.videolan.BDJClassFileTransformer.rename(BDJClassFileTransformer.java:64)
PrintStream.java:java.io.PrintStream.println:899: 	at java.base/org.videolan.mmbd.Adapter.<init>(Adapter.java:78)
PrintStream.java:java.io.PrintStream.println:899: 	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
PrintStream.java:java.io.PrintStream.println:899: 	at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
PrintStream.java:java.io.PrintStream.println:899: 	at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
PrintStream.java:java.io.PrintStream.println:899: 	at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
PrintStream.java:java.io.PrintStream.println:899: 	at java.base/java.lang.Class.newInstance(Class.java:584)
PrintStream.java:java.io.PrintStream.println:899: 	at java.base/org.videolan.Libbluray.loadAdapter(Libbluray.java:98)
PrintStream.java:java.io.PrintStream.println:899: 	at java.base/org.videolan.Libbluray.init(Libbluray.java:345)
bdj.c:733: Failed to initialize BD-J (uncaught exception)
GUIManager:0: ERROR: getInstance(): no instance !
bluray.c:3169: Can't play BD-J title 65535
[00007ff390000e60] libbluray access: Closing overlays.
I can reproduce this issue with all my BD+ played with vlc/makemkv and you?
legluondunet
Re: VLC, makemkv and BD+
No answer?
MakeMKV only uses an installed Java interpreter for playlist obfuscation. For BD+, it has its own limited interpreter for dealing with JUST BD+, when it is writing to a backup or MKV files.
The error says that VLC is trying to use Java, so this should be a VLC support issue.
legluondunet
Than you for your reply, but can you tell me if you can read BD+ with VLC and makemkv emulation?
That I cannot tell you - I do not operate MakeMKV in that mode. I have it create MKVs of the content immediately, and have VLC play those. Actually, I process them through handbrake and put them on the media server, because I don't want to waste the space, or have to go digging through disks to find what I want to play; it's all online.
I have no interest in the menus or most other features - I bought the disk for the movie or series, not for conversations with people on what THEY think of the show.
