Heads up - Support for LG UHD drives
Re: Heads up - Support for LG UHD drives
That's right (I knew it was IDE-something)!Well, then, I might be able to use the laptop for the procedure. Thanks!
An interesting thing ... I tried my flashed-but-flaky drive with DVDFab (1 month free trial) -- the drive kept getting stuck on the starting reads (as expected). Then I tried it with my nonflashed-and-good drive. Oddly enough, it ran without UHD-unfriendly errors. I was even able to copy a chapter off the disc in "MKV-passthru" format (a proper 4k rip, without the extra-junk of course
). So, what does that mean for the "unfriendly" BU50N and MakeMKV?
Are you sure that your current firmware on the good drive is UHD unfriendly? Have you tried to backup a UHD in makeMKV? Does makeMKV see the disc? Is libredrive enabled for the drive?BinkIE1 wrote: Fri May 31, 2019 5:36 pm An interesting thing ... I tried my flashed-but-flaky drive with DVDFab (1 month free trial) -- the drive kept getting stuck on the starting reads (as expected). Then I tried it with my nonflashed-and-good drive. Oddly enough, it ran without UHD-unfriendly errors. I was even able to copy a chapter off the disc in "MKV-passthru" format (a proper 4k rip, without the extra-junk of course). So, what does that mean for the "unfriendly" BU50N and MakeMKV?
The first thing I tried was to test the drives in MakeMKV. The flashed, flaky-drive was ... flaky, so no info of any value there. Then I re-tried my working drive (not flashed) -- "retried" because, before all this, I tried MakeMKV and it didn't work on the 4k disc. My good drive always could read the 4k directory ..
(click for larger size)
.. but it couldn't do anything else. Thinking it need help, I started looking into friendly & unfriendly drives and firmwares, and such.
Then after all the firmware info and testing on the flaky drive, I tried my good drive in DVDFab ..
.. and it worked perfect. I saved a disc "chapter" and can play it fine on MediaPlayerClassic. By "fine" I mean sluggish on this laptop.
In my testing the 2 drives in MakeMKV, I noted it's information ..
.. but must've deleted the log file. So I just ran it again to get the "debug log" ..
(click for larger size).. but it couldn't do anything else. Thinking it need help, I started looking into friendly & unfriendly drives and firmwares, and such.
(click for larger size).. and it worked perfect. I saved a disc "chapter" and can play it fine on MediaPlayerClassic. By "fine" I mean sluggish on this laptop.
(click for larger size).. but must've deleted the log file. So I just ran it again to get the "debug log" ..
("max characters limit" -- continued in next post)Debug log started at Sat Jun 01 21:51:39 2019 , written by MakeMKV v1.14.3 win(x64-release)
001005:0000 MakeMKV v1.14.3 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\1/MakeMKV_log.txt
005072:0000 Backing up disc into folder "D:/MakeMKV/2001_ A Space Odyssey"
005050:0000 Evaluation version, 15 day(s) out of 30 remaining
No SDF v042: HL-DT-ST_BD-RE_BU50N_0420_211605241901_KZ7G62G2938
DEBUG: Code 0 at 3n|Kn0<$@PHq+zen:213140564
DEBUG: Code 0 at jFJ/sedl|n^h9"'$:29401014
DEBUG: Code 2147483648 at 3n|Kn0<$@PHq+zen:29397035
DAFD=PAAAADAAAAEABDQgEHwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 0 at 9feUnk3-Vsu(9Z;UE:213130766
001003:0020 DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:121263521
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at 9feUnk3-Vsu(9Z;UE:213130306
001003:0020 DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:213131709
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 1 at rl(}K"Hk=3WvG?cj-F:121263521
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 1 at rl(}K"Hk=3WvG?cj-F:213131709
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 2 at rl(}K"Hk=3WvG?cj-F:121263521
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 2 at rl(}K"Hk=3WvG?cj-F:213131709
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 3 at rl(}K"Hk=3WvG?cj-F:121263521
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 3 at rl(}K"Hk=3WvG?cj-F:213131709
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:213130904
001003:0020 DEBUG: Code 1 at rl(}K"Hk=3WvG?cj-F:213130904
001003:0020 DEBUG: Code 2 at rl(}K"Hk=3WvG?cj-F:213130904
001003:0020 DEBUG: Code 3 at rl(}K"Hk=3WvG?cj-F:213130904
001003:0020 DEBUG: Code 4 at rl(}K"Hk=3WvG?cj-F:213130904
(continued from previous post)
So what do you make of this?DEBUG: Code 0 at 9feUnk3-Vsu(9Z;UE:213130306
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
001003:0020 DEBUG: Code 0 at rl(}K"Hk=3WvG?cj-F:213132721
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003332:0000 Saved AACS dump file as D:/MakeMKV/MKB20_v66_2001_A_Space_Odyssey_C6EF.tgz
003346:0000 LibreDrive compatible drive is required to open this disc - video can't be decrypted.
001003:0020 DEBUG: Code 0 at jFJ/sedl|n^h9"'$:29396115
001003:0020 DEBUG: Code 0 at g75u^zn^>U:IVZGA(]>:213141116
001003:0020 DEBUG: Code 0 at \njBo?vhlq/vib}6Jnjy:29396713
005069:0080 Backup failed
005080:0204 Backup failed.
Application exited at Sat Jun 01 21:56:17 2019
You don't have libredrive enabled a UHD official drive won't work without itBinkIE1 wrote: Sat Jun 01, 2019 11:28 pm The first thing I tried was to test the drives in MakeMKV. The flashed, flaky-drive was ... flaky, so no info of any value there. Then I re-tried my working drive (not flashed) -- "retried" because, before all this, I tried MakeMKV and it didn't work on the 4k disc. My good drive always could read the 4k directory ..
Ok, Please go into Preferences in MakeMKV and make sure that 'enable to contact webserver for updates' is checked. Restart MakeMKV and insert UHD disc and start backup to Folder.BinkIE1 wrote: Sat Jun 01, 2019 11:29 pm (continued from previous post)
MakeMKV should now contact the server and download LibreDrive and also the latest UHD Volume keys.
Hopefully this solves your problem. It look as though your firmware is UHD compatible.
Let us know how you go!
Thanks again, guys, for the info & suggestions! That did it!
That means the BU50N (0420) drive is UHD friendly right out of the box? Excellent!
Would that also mean the firmware 0420 is the most up-to-date firmware (so far) for the BU50N and possibly the BU40N (is it something MakeMKV could use)?
(click for larger size).. at which point I cancelled because I don't have room for a full save. (Any way to save just an arbitrary sequence, as a test?)Debug log started at Sun Jun 02 20:13:56 2019 , written by MakeMKV v1.14.3 win(x64-release)
005072:0000 Backing up disc into folder "C:/Video/backup/2001_ A Space Odyssey"
005050:0000 Evaluation version, 14 day(s) out of 30 remaining
003338:0000 Downloading latest SDF to D:/MakeMKV ...
SDF v05c: HL-DT-ST_BD-RE_BU50N_0420_211605241901_KZ7G62G2938
001011:0000 Using LibreDrive mode (v05 id=F2F9E21FAD1B)
003338:0000 Downloading latest HK to D:/MakeMKV ...
001003:0020 DEBUG: Code 100941314 at 4X{Lph=CO%SPL}/b:121269317
001003:0020 DEBUG: Code 100941314 at zIXo_7or$zz=7,>!:121262417
001003:0020 DEBUG: Code 100864261 at 4X{Lph=CO%SPL}/b:121269317
001003:0020 DEBUG: Code 100864261 at zIXo_7or$zz=7,>!:121262417
005038:0308 The total size of all output files may reach as much as 82134 megabytes while there are only 20200 megabytes free on the destination drive. Do you still want to continue?
001003:0020 DEBUG: Code 0 at \njBo?vhlq/vib}6Jnjy:121265154
Application exited at Sun Jun 02 20:21:05 2019
It could prove useful. If you would like to help, are you able to extract the firmware using DOSFLASH?BinkIE1 wrote: Sun Jun 02, 2019 9:30 pm Thanks again, guys, for the info & suggestions! That did it!
I checked my system but no SATA - IDE mode in the BIOS. So the laptop is useless for that task. I'll have to wait until I dig out my old system, determine if it has the IDE mode, figure out a way to connect my laptop drive to it (probably an external adapter?), and go from there.
Any instructions here for a best and most reliable way to go about the whole procedure? It may be some time before I can get into it, but, yes, I'd send you whatever I get from it for your research.
Since people rarely search for this stuff, the actual requirement is:BinkIE1 wrote: Mon Jun 03, 2019 4:21 pm I checked my system but no SATA - IDE mode in the BIOS. So the laptop is useless for that task. I'll have to wait until I dig out my old system, determine if it has the IDE mode, figure out a way to connect my laptop drive to it (probably an external adapter?), and go from there.
Any instructions here for a best and most reliable way to go about the whole procedure? It may be some time before I can get into it, but, yes, I'd send you whatever I get from it for your research.![]()
"A motherboard having SATA controller set as IDE (not AHCI !!!)".
My interpretation is that if the BIOS offers no 'AHCI' mode, you're probably good (older BIOS).
The entire procedure is detailed in the 1st post of this thread:
https://www.makemkv.com/forum/viewtopic ... 16&t=17058
Suggestion... the procedure offers both DOS & Windows options. Pick one & focus on ONLY those details. Also, while use of a hex editor is mentioned, there is a 'data mover' tool available which performs this task for you... MUCH easier. Read carefully.
Thanks! Will do.
Another option is to contact mike admin who may be able to extract your firmware over the internet.
He has done it before...
Whoa!
You guys are *¨*:•.magic.•:*¨* !
I'll check with him on that. Thanks.
@ mike admin - check your PMs
